Well, I've commuted by bike every day this winter and my Pearson isn't really that dirty. I wonder if after all this wet weather I should look at cleaning out the BB? My wheel hubs are sealed so I assume they should be okay.
^Conversely I didn't need the lights on the ride home last night. And I wore shorts. In February!
so commuters.. how dirty are your bikes these days?![]()
Looks like the only option is for you to buy carbon wheels.![]()
im going to change my brake pads for my CX bike, not sure which ones will fit
seen these on wiggle and the reviews suggest they will
http://www.wiggle.co.uk/kool-stop-tectonic-multi-compound-pair-of-brake-blocks/
so are my dirty caliper brakespfth disks.
55mm shimano etc pads99% sure this will be the case.
http://www.ebay.co.uk/itm/4Pair-8-O...sure_cycling_bikeparts_SR&hash=item2c6b463965
been using these for ages.. great pads for the price - 8 in a pack for 8ish quid! and fit my 55mm brakes no problems! my brother has been using them too and he likes them! give them a shot tbh.. can't go wrong for the price
thanks
I assume I can change the pads then and not the whole thing? I shall have to check)
cheers
Be careful out there Frenchy:
http://road.cc/content/news/110791-witness-appeal-after-cyclist-killed-manchesters-wilmslow-road
