- 25 Nov 2011
- The KOP
So it would seem the Mantle performance issue was Dice not AMD
So now proper testing?
Mantle
-Fix for a crash that would occur when activating full screen in portrait mode
-Fix for stuttering that could appear during video sequences on multi-GPU PCs
-Fix for a memory system leak that could cause stalls, which would result in frames taking longer to process
-Reduced the amount of stalls that occurred when running with high graphics setting that require more GPU memory than is currently available
-Fixed screenshots on multi-GPU PCs
Mantle
try running Heaven 4.0 please.
