If you have a cold, i would recommed T-juice's Affro Dizzack juice.
It tastes exactly like the old fashioned cough sweets, great for a palette cleanser or when u have a cold![]()
That's a flippin' cracking idea; wish I had some now.
bloomin' eck, splendind selection to go at there; got to be a few keepers in that lot. lol I'll keep quiet, don't want to curse you, what with your current luck with flavours.![]()
Merlin don't put the triphammer fruit pastels into a poly tank as it will knacker it. Lovely juice though. New Kayfun tank arrived this morning...![]()
Merlin5, you MUST let me know if TripHammers' "Fruit Pastille" is nice!
Hmm thats interesting pestilence - may thats why I have not been getting on with the kanger dual coils in the Aerotank - they loose vapour and flavour after half a tank maybe its because i have been using Trips juice exclusively... Trip juice is always a 50/50 blend to my knowledge.
Anyway moot point now.
I have got the hang of microcoils now - can bang them out pretty consistently with few "coil corpses" and at similar ohmage.
I have recoiled the IGO-W now and it is amazing - yes IT IS better than the Kayfun - pfft a 10 quid atty outperforming a 65 quid one. More expensive is not always better.
I think dripping may be the way forward (for me at least). I really don't mind having to drip - I like the convenience of being able to change juice on the fly and am happy to see the back of a soggy pocket on the tube when a tank springs a leak. - just wish I could adjust the airflow so I'm looking at an adjustable airflow dripper next. Any suggestions?
Good call Tauren thanks
My Kanger mini protank V2 arrived today with some Dekang Crystal Menthol and it is a very good taste. Not quite feeling the replacement for ciggies but it is a good substitute and working nicely for now.
Has anyone tried juice from http://www.yaeliq.com/ they have a half price sale at the mo and they have some really nice sounding juices.
Check out torchy's batteries on ebay, his own brand are good for someone just starting. If this is your first time make sure you have an ohm meter in order to measure what your coils are running at in order to avoid over straining the batteries.
Thank you, have a pair in the post
Just need an ohm reader and a kick now!
Although if I have an ohm reader and be careful with my coiling, I'm getting the impression they are not strictly a necessity.
Should I be OK trying out a few coils and using the kfl ato with my standard ego started battery (900mah) to see if I'm doing it right initially?
No. Unless you're certain you've coiled over 1.5 Ohms (without a Multimeter or ohm reader, you can have a rough idea, but not certain) - and that you haven't caused a short somewhere, don't use an Ego. The risk of causing a violent discharge isn't worth it.
Sorry, I meant with the use of an ohm reader to ensure the required resistance.
Bloody good prices, (literally) Kosher ingredients, some fantastic flavours. The only "But": they'll need a damn good steep - Yellow Custard took 4 weeks to become acceptable - I've found warm bath or ultrasonic steeping helps speed this up a little bit.
Buy with confidence![]()
