290 power query.
11 Feb 2014
Have just purchased and nice shiny 290 msi for a new system but im not 100% sure how to power it.
I have a corsair rm650 to power it which has a single cable with 2 (6+2) PCIe connectors on the end.
I'm not sure if this single cable will be able to deliver enough power or if I need to connect a second to the psu.
Hello and welcome to the forum :)
As almighty15 mentions, both power connections will be needed.
The single cable with dual connectors should be fine but due to the high power consumption of the card I'd use individual ones if possible.
The RM650 comes with 4 pci-e connectors so you should have another one around somewhere.
pretty sure im using 1 cable with my rm 650 and 290 and dont have any crashes or anything
Yeah it shouldn't cause crashes...but ever since I saw a pic of one of those '2 pci plugs on 1' cables being burnt @ the psu side apparently from excessive current I'd recommend using 2 separate cables on high end cards to be extra safe :D
Edit: read it wrong, thought only one cable was plugged in, was confused to how it was turning on at all. Will leave my reply unedited int eh spoilers anyway.
I would avoid doing this!!!
Your 290 is drawing all the power it cant get through the 150w cable, through the motherboards PCIe!
The 290/290x imo should have come with two 8 pins rather than a 6+8, as when the cards get toast, they really start to draw more power than you can deliver to them. Some people have even said the 290x's break 300w at stock clocks when they are a little toasty. I believe the 6 pins can deliver 75w and the 8 pin 150w. I bet your motherboard is under a fair bit of stress from having just one plugged in.
Keeping the card cool will reduce its power consumption. Not massively but you might find a drop of 20-30w when going from 90-ish reference temps to 50-60 aftermarket cooler temps.
If the PSU cable comes standard with two 6+2 mon one cable, i assume it is capable of delivering that power through the cable. Would still feel more comfortable with two separate cables.
In that case I'm hoping it's a dodgy windows install and not the card.
What kind of crashes?
I think you've misunderstood him. He's using 2 pci connectors but they are both on the same cable which is getting very common these days.
It's the same people who buy like random asian knockoff power supplies then wonder why the voltage is going all over shop.
If you've got a quality PSU, a single cable is just fine
Pretty sure it was a high quality psu, will try find the link.
Edit - Found it
http://forums.overclockers.co.uk/showthread.php?p=25558301
This was the 6+2 pin PCI-E cable connected to my 7990 graphics cards, so i'm assuming that the single modular cable to 2x8pin connectors simply couldn't handle the current that my card was drawing
I had something similar to this happen on my PSU plug when i had my 290x powered by a single rail PSU with easily enough current on the 12v to power it. Reason why i think it happened was because i used a a 6+8 on the same wire like you did. To be fair, it worked fine for a few weeks, mining away with some of my other cards. Though these PSU's go through quality testing that require them to be under heavy load for extended periods, there is also luck of the draw and PSU degradation. Wouldn't use a single wire if you have other options available.
This is not my picture but mine was arguably worse, with the GPU 6 pin practically black and half melted from its original red colour.
data:image/jpeg;base64,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[COLOR="Yellow"]*[/COLOR][COLOR="Yellow"]*[/COLOR][COLOR="Yellow"]*[/COLOR]1NBddNmVbhHNcZYwBR8VxwCmJLHdTz5ewqW2jwpbGhTBjqo6c8mgFb2ZhkJOVPMDGegqW75DnSumQAB6TJA5AdaHjLpNsrpMDLFsxmc9T2py3yQtySDsFbEg4z/FUIt8MyrEyhg+Dcydo5AdaEX7pIWdBILZEwCYA9YFTijelmVYADc/MwHhx6k//AG96gum3bYu7O3NdM7DIUDJzRDNctpZpuQSozpjaWxn0rLw5EOtxpFuMggZGdh5R2oOK4cxb0XNIJ0qp2Scsf73xidqZx9pEB8qMfzxKlmIAJHNsRvVBiyQCV8cHA2zmZ7bVWm7pEuA2wG8mBQC0s6luAAkwB7TOcnBqabaso1Ehp8xyI5isVXcQaUZWIkxpPUnJPy2p923bMnKcgRseZMczjekcLdS2WRlIU+Wf0gcvnvSTetQcP4pC7nSPLgVA2xaskCCX0gAAdZ1T600KjBrYhtEFcfmjnOCaXeu2wqG0IYGAV6YmeWw3NP06nW6sBYIxvuMj+aCDjTbt+IDwjxA5M9uppJuW5ACHEEnfI2B75NRvxElpVdQwFkZkz/FNXiXkBvAZB0n8xImAaDO7sHHh3kmNgOUnr2rfaY1y7NpodWOjMkDlPKeZrDe4i6vl2wSeUdqx1XR6PjFlPTPtXM+JXL/F/wCsDZCkWWYGdXiAj9jM+1K4f+qeHcAkOs9p+lXVspSbcIen4fiK6Fu/jvy9a89+HcfauTocGOUwfkc11bZpWWu1ZidJY04s86n+prL+IqVumOecd6GTWUMZa/8AVUtrwNZHalm7TQdfgnG1J4l6z8JczT+MEGrEGhdlhjUJHSm8NxaCIUoB4VJ5zBIFZLZY+QA7TmIBrb/qHe2UFsyRhdjHXtUUXFXlW6rgbD2YntHiaicvb1XVAZWknSNo682P8VLJLAB4VrW3c/xQ/wC/KjAXUCWG3Ux/nOgK3xt06j5ZYKsjtJP2p5SLai44DGBqXBLHkB3pFh7pM6iXIJ0HC6ZxJ9KXeZTbNwY0kkqfDMdz5V+tUaFL/EKXD5h+U4UbY5k85pKcMwICabg1eGTGgKNzM6jPPvRraVgjHFyMsOgyRnlS7g1eI3V1MoVQNgCZJ7kgUQV2wdYLs4UaSNO0iS0mNpI6bVL5W8zoWIGkQ4IlgTlRzAxBNJDpbLBHJVBLhjg6juSRyzjpVXrSI4dJgnU5j5Anko5LVB/h+kWycHcBAIAAwAs59+dJvJZJ+I1xgEeQu4kArHfxGfUCnX76sW1ppkjIwSFz8hQcPdt6gbQ0soKKDtk6miee2aCWXTSVRJx+YbLsT9aif7qFVGRmWEHTO3bA2ort1xpeA2eXLlp770bpcUll8THdds7QOtYqK7xWvwm3IGWkbCJH0qWLxUljbC4AmZwc56ZpbfGMLOncljnmMfKaYw1B1WFHmJOZ/wC8UAWCfiOrLp1/so5xsBn3q2suNOmWgNpiIwOfvRKFfQ7MQxBiDiPvgb0DcKxiGCgwIH5QJn1moH3bjwCdIjEcyevYb/Os91jdKOSAi7MdyZ2E7A9agsKWUOdSyNJPIgbnr6UQvjVcDQwWAoj3opvGWVkuCM4IJ36DtXP4jgiQRrAkydPIAQAKbf4dDDNdMAg6SOYzQXOFRFLT4oyZwYnB6DNSRxuK4JXGc6pg+nLvXkn4c2mOPATHv/P1r315A6o6r4jE6dgOcTt686xfillXBJA0sAFPrjFYyzpeaWi1ebx92yB3B2NS3xNy0Qbdy4oG6qxA+UxWi5a+GxttlT5W+o9RSzb3B3X9xWvjWXuUjHtOPh/E/nJyOMvul8Xg7FmIfVJmZ59fTpXb4f8ArziFnWtp47Ffoa4v4tZgD9q59vJ9RW+s6w8TNinHeaS+iWf6wRlJew2ApJRg2+OYHPvTbX9ScK48xWCPMpG8x1HI14xH024/VbA+RBrCnlI6vbHyD/zWXVorOtdfN9U4PirLeS6hPTUJ+VB+OfiYSFEFyNunc/xzivA/h1uXY9AP3muz+HcPN1R3UfetOTJMTNYd+z7PFqxkty48PJ65boAMwV/WBGkjABzk1qe7cVhJBBGW6KPv2rnW9Tq1vyaTLR88H703g3V7YmdXIrmAenWtribbHCgSwyrCdL8ydyT9qVe4R28OvTOpiVO0nAHtNKNsmGN1dPi0/QT6Zo7PCosKSwc5mcNA/YUGss1t1XXKtgH9Mdc5J+1VwfDoGZS2pRybOonm0/QVk4sgorKGZ9pAnB5ryHrT34tTpJWVC+aec7DqaqJdto2pfiG34TqAgzqwMnbY4pnC8LbbVEFXkhwcjGkBemBvWYcdZZlQrGnxE/8AhjxH1NH+IKgNvRJYkA6Buo5EbBRNAVvilcFWCnQ0W46jbfdqPgnCAajpKjKzOTkknmagtJqF4qNOmF7TvA2HrWY8YGIOlXQSQY2kwAOp3oIvFIy//CJZ5MiZhuc8gQtFxPGC5b8KE48MYInnMeEd60NxDWwXZFQHBzsBgUq2bmtyV0hh7kDmfsKoCzc86udRUiNPU52pl+QZNxd5zgnGx9zSjxCk/piAGHU4250pbNlmBJ1AA4PMkzP7VipvwTbSS+v9Snn6HkKfCrcAkkESRyAGAo5RmkJ8N2dQJgiBvDfT2q14ookMPKCWB3n7mgZce2RpLG2CDIA5bCOlVasoYKliTzGwX7DvS1e0SIQyIknORsD7mn3OJ0MNSnO4Hl08pP2qBd9VuIrjLDHh2AmCR/NO4ooyhjBBGldJznEio1tk1nwoGjPQDt9qR/qiJ02tRMgQIkCM9t6Crd6zq8KkkbA82P1OKpmGWugCdrZ6k8+pOKZcugW9CW5ZcKBuDtI/mqTiNek4BWYn8xAg6T96Kl2+QwNwwBJhfLGNz1rEbqkljaJaYX/j0HLfetXE8WE020XxEgMDsBuSf3qJxVzzlIBiD0HOegrGRw/x7hFuWtKrDjKjvz9elec4O9qAPMYPodv87V7qzaZryuYhhAO+N/YY968ARpvsBsS4+TY+taJvraado1ehsGSceWO08Psz/jSwkdG/auPwy+JfQ/Sut/Uh8UVg4Ncsf0qfma3U4VXbZi216dtDeMaFtf8AhRcLZHw0bmWc+wAUfuWoPxfBUfpUD6fxWkLCKo5AD+f3NdFY8Ws9Hj49ZpER1+rofhdmV/8ANs+g/wCprr8CNLA9Mme+PpWTgrUCOSiP5ro8HaDhv1br6+nOuCs7+TX1+z388RgwafDSPq6awl0QSQwkz9OgHanMqhsk292xzUY/4is/C37YtRc/L9RRxbJKkOZABJMxzzXW8Y/hEgD4TBlEISeXU9yadZuqtxrZOtIGDMyf1Hb0FI4h2CEDIY+EoOfp96ZcUMqlVBKmTHM+nM/SgPg7/wAJn1hhqM5/SNuwHaht37ZcsLRJ2UD+zOBtgmqf8QmVYg58SnYaRJnvtTeHvs4DuiiV8JByA2/psKqG2jpUqtuAMsG75P8A5GeVI4O+/iVTpJkktnTPl1ARHZfnR8ReuqUadXIaeZPID23NHw10lncHVmGHJSu8dT1PaqEcXedVEhiYJSMgkYkx67U5b94zADLbMEfqIH5eW5/aqtfGHlUqDAAYzGCSx57wKAtctsqs2rV+YYzznoO9QVdt/EVtLDBhhvpjkvVvXan8KGaGmGAxmQAeR6msq8OwLAsGH5h+qeQ6AfvRcVw8SEuhBB35chpjYCqFnigQjfD1OYAO3KafdZipATCiIG89v5peq5liVAyAOfr/ANVSagUOqVbAMZzkk9I6VipqSdFxAMArHfaR/NVZ4pxELOYEjmTy7ACiS3nwnVkxOIPerUXIy4kYA69+3OgdbRz4SNP5iB+Y84P3pNk6rZQwugjvmZjO5pd93UKwOJIg7yTHsKO9bBLBTPMhtifXkKA7jvqHhbJEncRBOKsX7sarhVQRMDcDnQNZec3AFAJMe0DPQVSWCwJLw0YYbQegO570FtdKMrKJVwFDc4yZbp2orgAU6AzH/wDKCdhOwpPAcSChMaoOlYkkAY9z3pl0G4Z+IAEOw3ONj0zUUVtrpn8vmJkbZgR+9IuM91WTUBjJ3Efc03jW0pq1aoGR1P8AFBetAsoVjkbDaByHTfesbaRGsrCfhRAR2JnQGAzPbJ6mvnyJqug/2yf+bE/QV7b+pOLFnhtAIDXfD7DzN6CvFWWGlrjYV5IH/wBNBH8D/ka4tmn2trZI5Twj0dePwWif08Z/P2c38Su67s8gNX/8/tFVwFnyrzbxN6DP8UgvjU29xtRHYbAeprWT8O2znzXMDsK9CKuLNmtxt/lb682S4fi3e0z7CunwiS09NvWsXAWoWebfSu9+HW9K6vlU2m+5j3etnV/TcEXvvT7tWqQulN5ya3EBSGyAY0noOY7CsNk61YADVvnp/nKun/qQANIkndeoJjNa8NNypte0e2yaxyjkevHqWBChogA92/8AVOsXQGAYFSZLIcg8t6Sr4/8Ah+ASPDvIwIHvRcTLW1gSFbxMeUdYyTW1ytNlyHcRpDcj0HOOS0QDoi28kSIZB74HIU2yGcK/aCh6dT/FBe+KJdAFwYXq0iPYVUSzeusNPw1kgFtWAAScHqYFWtw+K2iw7CdLGcbZ7dqjvCEl2beQozHaKU4ZbiAPOrAnACjfH5m70DOBRghkHQnOdJMbmBstQ8PcjSrrpwS225yAOsc5qXfzBGCmQDMlZOfpSbnAnVBbWpksFJU5gKN9gBQaIIgvcgk6VUdzj1MfelfiC6ULajIwABOevc/tRvctrcVMHUCcnIiPL896G2ArQDpk4J/SP0jnvk1QbhWCyCQoJLAxnv1rJpszpNwliVJnchPoJpt7j0EkKWAMADMkCTA60HDvbClCkzOrVvkzB9zQMtaAR4zzAJORA3HWq4dgBpIJIMDeQOuee+aQX+IAFWXG5PhISfnBA94rRf4oY1gGeQwQBnNYqhRGAPxOoEdJz6nFNsoikfpmBJzPUd6RK7LaywwD07dBmiEOpULL50/lx9h3oCF1V1giRPhB+udzVMiQdVyACIU9R1PuKnF8epUKyScLHMAmPlUtXFBB+HA2WdiSf+qCxaRATqJjJnYmKO6FnUsxGc42wOwoXcJ4bgBLZVeQPbrU4dEQS5j3kEk79zUDEvABJcB2ABIGI3wPvSeF4O0DBfWMnpLEzJ68qyXeOtaWJSGadzy29pFcv8U/qIACYAG3L5czWucteUcZ+Dspsd5jev4Y7z9nbtlNTWyC640g9ZzJ5/ah478Xt8In+40sZOkHJ7D+a8Vd/q18pw6+I7u2W9l2UdyTXOs8C1xi95iZ3kyT7/auTJiyZuF53a9o5z59oZ1pWbbuGJme8t/+ofjbjXLnhtKIMbAckXrPM0j8V4k3SqLj4hAH9ttdvmZPsKnH8XMWl8KDkOXX3j7Vj4cltbgQXi1bHQcz7LHzrtx1isaRHDo17TNcdfZVnXrafj29DOFsC9cLbWk59hge5+9B+IP8W6F2G0dAN/4rosy2rXh8o8v97829BXO/DbeC3NsD0ropG9OnTq4JpaIi9uc+7HaO/nPy83Q4e1qaOQ39P8+ldFr0MpGw270iymNK78638Nb1gAgiNj0jrXLaZyZJvPo9HJeMOKMFf9vNrs2NJLDIbJA3H81pR3AIEKJOWGwA3PvQWOHYEGRE7g7wM45ZrTw9i7M6pMCQdhvMdTW1xNXDsRpYgTEAjnQcKSXa22AZLEYieQ6+tZ7jSvxQSun8h694+lbL1lI1zpYDJ69J7UEPC3VlEZYIOTjT+kd/WonCGQNTSPLBxgfm65zS0sRAe4CxgmMYG4HzqnK2wNDGJCgNn1jmTn9qIcNLlkcmQBqYY1fLIWq4S8CgnJJ5CCB9vekuFt3FbIXfsWPU7k9BTuJ4u0WAIMwWYrjG2T71QBFtoY3GIDEhY64B64z86l5UVCV8MAzc3kxAn9XpV8M9oMAhKEjTB3Kr0nud6Vw18W7pRQQhhUBjTMZ0jf1JoAvWgVBAMiDdjBMCfFucfpHWn3ONDwp0tqhdJ75z0ECrk2iPAcGAVEglj9uZNIHFOY8CqSC5LCOYAB7xQNt8TqWfhgKR4SDnxem3rS+M41lCEiQDAIzJ7Dn70TXtJZVUB2UQDjG0xyFZLVsG2VckC3EHadPMgbL2qo1ayGLLBZhqK7HHTrvTOHLnUGRZJmT05Seu9YbZBAAYAYM/m38vYYp1okYZ9RjUw2gDpWLJrvNcZSRByJ/tj6+gogW1C4vmYeXYgDO/P0rOMXILyrDboANh88k0x+H/ACoyjG8+UdB19aAhfvz5BLbTyEbnpmiYu0jGAYUHf35ClLbffXlpAXt1+VYON4xbSBy4EjY8s523JqTOkayyrSbTpDbbueAsx8Q8Ixv1jmK4P4z/AFCiDSOWyjMV578R/HHunRZUgGcDzH+KbwH9PR4rx/4j/M/sPWubLkiI8c6fDrLrx2rj/txrb9U8o8o+ssZ4y/xDRbB9sx6nYU+3+AhfFeeT+lfu259q6z8aFGi2BA5DYetYyxbJPv8AwK01yZL+7G7H7unHst8072SdVpbUYVQByUffrWXjuMCYmW6/p9O9L43jwgIQ55muJq1GTtXVjx6Mtp2qmKvssPPrP51+RzEmFHmYwB6/yfpXX4HhA7xMWrQgt1/VHqR+1c3grZMMPM0hew5t9hW/ieIAUW7YOgGAObt/m/y61tmXn4KV9+/KOneeyuOu/HuBVEKBgDkv8nH7Vr4e30GFxVf6f4K6d7hy5/u5L6KD8z2rZwlkHwE98czWyPDj8/l/1rzWtbNrPOOfn29Pm0cPZOsGfN9q6fDWtJIUhc8xjvFZ/wAPCaYuSCD6EU8IpxqY6hIx5Q3p6b1rhrMt2ARk61G8H8xM1sW8Dc0gwCJ3yPSlBlVGIgEYEdsCY3NHdbUoZUyCNfXHXr6VQ3g7ugsgWB+XG46jr60u5btGZ1LpgFQZEjxH1o7nEhjDCZIXTzHPPTFVb4lcEKUBypjBLdPYUQ0IjAkLqY+Zug39hQ27ouIYy+QjRpx2nYd6HjbwDKyiFEljMA+v6m7VoY+LUwEEbDfHXtVC24tbYUCAQDIOZgZjqZpYdAIFrY+Ijl+aD19KJeIaZVJGAhIyZydxttTrFxgAWRQ25jIk0COOvm4sqvMS22kDOYz7d6Iq7hbi4YYCnGMZPTA2pXCu2p1bw6pYkDadoP5j3oER8LbZSviEn8sYA/uzzqguJe+VJURpU6c7tsP5oeJR0XU7C6AdW2VA2gAeJpoPhHVBLnICQcAKuS0ciTzoDYYqy3HmIkjAfGdsqv70Qy7qLhtQloAG2kDJ7sx+QpVy2Fgg6CxGDkSZJP8A5H7Um04NsAiT28OkdADlRHXNZb9206jxsS0hewboPQbnvQf/2Q==
What the link
Sorry i dont know which of those forceful porn pop up codes i linked you, will edit it with something less exciting :)
That's better! :D I was able to get half way down the picture from the original code quoted, but then it broke up and scrambled after that.
Turned out to be nowhere near as exciting as I was hoping - no flames, explosions, fast bikes/cars or boobs in sight anywhere. :eek:
