Does CPU effect it much as I have a poor 4770k so cannot clock?
If so no point for me even clocking GPU's high.
With the GPU settings used the CPU does not need to clock and has very little effect on the results.
4770k @ 4.3 Titan @ 1097/1645
Sniper Elite V2 Benchmark Report
Created: 2014-02-22 at 15:06:37
Build Version: 1.05, Jun 7 2012
Average FPS: 53.2
Minimum FPS: 23.1
Maximum FPS: 237.4
Number Of Frames: 4072
Average Frame: 18.799ms
Minimum Frame: 4.212ms
Maximum Frame: 43.298ms
Machine Name: KENNY-PC
Monitors: 1
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 8146MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX TITAN
Feature Level: DX11.0
Driver version: 9.18.13.3489
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
Back on stock Titan bios for now until i put my block back on.
Ah Jesus not another benchmark to attempt![]()
Radeon 7870XT @ 1150 / 1575
AMD Phenom II x6 1090T @ 3.2Ghz (stock)
26.5
Created: 2014-02-22 at 15:58:06
Average FPS: 26.5
Minimum FPS: 12.7
Maximum FPS: 210.2
Number Of Frames: 2024
Average Frame: 37.762ms
Minimum Frame: 4.757ms
Maximum Frame: 78.681ms
Machine Name: HOME
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 8153MB
CPU: AMD Phenom(tm) II X6 1090T Processor
Number of Cores: 6
GPU Name: AMD Radeon HD 7800 Series
Driver version: 8.17.10.1267
Dedicated VRAM: 2030MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Most people call me Kaapstad.![]()
Created: 2014-02-22 at 18:01:08
Average FPS: 56.1
Minimum FPS: 22.2
Maximum FPS: 223.7
Number Of Frames: 4295
Average Frame: 17.817ms
Minimum Frame: 4.470ms
Maximum Frame: 45.071ms
Machine Name: jh30uk
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 16322MB
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 780 Ti
Dedicated VRAM: 2963MB
Resolution Height: 1200
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Thanks, Do you think if I could run 1080p and OC CPU it would go up by much?
Wonder if it can run Windowed (full game no doubt does) and if that would be fair.
