Sniper Elite V2 Benchmark
4770k @ 4.3 Titan @ 1097/1645
Sniper Elite V2 Benchmark Report
Created: 2014-02-22 at 15:06:37
Build Version: 1.05, Jun 7 2012
Average FPS: 53.2
Minimum FPS: 23.1
Maximum FPS: 237.4
Number Of Frames: 4072
Average Frame: 18.799ms
Minimum Frame: 4.212ms
Maximum Frame: 43.298ms
Machine Name: KENNY-PC
Monitors: 1
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 8146MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX TITAN
Feature Level: DX11.0
Driver version: 9.18.13.3489
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
Back on stock Titan bios for now until i put my block back on.
Average FPS: 53.2
Minimum FPS: 23.1
Maximum FPS: 237.4
Monitors: 1
System RAM: 8146MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
And on the scoreboard.:)
Radeon 7870XT @ 1150 / 1575
AMD Phenom II x6 1090T @ 3.2Ghz (stock)
26.5
Created: 2014-02-22 at 15:58:06
Average FPS: 26.5
Minimum FPS: 12.7
Maximum FPS: 210.2
Number Of Frames: 2024
Average Frame: 37.762ms
Minimum Frame: 4.757ms
Maximum Frame: 78.681ms
Machine Name: HOME
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 8153MB
CPU: AMD Phenom(tm) II X6 1090T Processor
Number of Cores: 6
GPU Name: AMD Radeon HD 7800 Series
Driver version: 8.17.10.1267
Dedicated VRAM: 2030MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Done ^^^
You don't need to have the game to run this bench.
You can DL the Benchmark on its own here.
To match the game setting rules go to (Documents\SniperEliteV2_Benchmark) and open the settings.ini file with Notpad, scrole down to the bottom and change the highlighted values to what you see in the picture attached to this post.
I found the file after I uninstalled the standlone bench lol.
I do own it on Steam and completed it at new and both Zombie games.
26.5
Average FPS: 26.5
Minimum FPS: 12.7
Maximum FPS: 210.2
Machine Name: HOME
Monitors: 1
System RAM: 8153MB
Number of Cores: 6
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Scoreboard updated.:)
Thanks ^^^^ far behind a 290, but it may surprise you to know that my GPU usage never fell below 99% during the bench. :)
I set the standalone to the settings shown apart from I need run 1920x1200 and 4770k is stock as a POS.
It got 56 the 1st time then ran crap after that, I assume the AVG 56FPS is the score?
I think I read AB may not be allowing proper voltage control on my 780Ti, I only swapped from Precision to it to get stats on COD-Ghost.
Created: 2014-02-22 at 18:01:08
Average FPS: 56.1
Minimum FPS: 22.2
Maximum FPS: 223.7
Number Of Frames: 4295
Average Frame: 17.817ms
Minimum Frame: 4.470ms
Maximum Frame: 45.071ms
Machine Name: jh30uk
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 16322MB
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 780 Ti
Dedicated VRAM: 2963MB
Resolution Height: 1200
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Average FPS: 56.1
Minimum FPS: 22.2
Maximum FPS: 223.7
Monitors: 1
System RAM: 16322MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Thanks, Do you think if I could run 1080p and OC CPU it would go up by much?
Wonder if it can run Windowed (full game no doubt does) and if that would be fair.
You should be able to run full screen @1080p and yes you would get a nice increase to about 62 or 63fps
Well locking it to 1920x1080 does not mess up my screen and totally kill performance like it does in Heaven, so this is 1920x1080 again no OC on POS CPU.
Good guesstimate BTW. :)
Created: 2014-02-22 at 18:30:13
Average FPS: 61.3
Minimum FPS: 23.6
Maximum FPS: 230.7
Number Of Frames: 4693
Average Frame: 16.308ms
Minimum Frame: 4.335ms
Maximum Frame: 42.378ms
Monitors: 1
System RAM: 16322MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
