Oh lol, now your just reduced to making blanket statements.
Its no good saying But but but in this case or that case... its not so bad.... and so on. thats a poor argument. it really is. Mantle just does the job DX cant regardless, no need for compromise.
The 290X is cheaper than the 780TI, it has More vRam, the performance is the same in DX, its much better in Mantle and the 780TI does not have Mantle.
Passion for a product can have us backing our favourite colour. at the end of the day your arguing against something that is plenty independently evident.
In this case the 290X is just plain and simple the better option, there are opportunities where the 780TI is, this isn't it. no matter how hard you try, and its an individuals money thats being played with here.
The 780TI is a lesser yet more expensive compromise, the 290X is the real thing.
Humbug do you have a 290x ?
Turn AA off and what I say is true.
at 2560x1600 AA isn't exactly required.
It does happen. If I had time to **** about installing Crysis 3 and benching i would prove it.
I'd say grab a 780 and keep the change.
Ahhh but you did say "Max", which to me means full details. Thanks for clarifying that you wasn't running max and that you turned AA off![]()
(For me)Should I wait then as its very important that its only a single card ! As I don't want any of this SLI stuff, maybe I should just wait another 6 months.
Everyone has gone round the houses here. The OP has £600 to spend. If he wants to max out games and run at 60 fps, and be good for 2 or 3 years he has to go SLI or crossfire. One of anything right now does not cut it. End of story.
Up the budget a tiny bit, or find used, and get 2 x 780 or 2 x 290. Job done.
A little bit misleading I find both a 290x and 780ti do a perfect job at 1440p and I run all the settings at max. I think the occasional unnoticeable drop below 60fps is more than acceptable especially as it is in generally poorly optimised games. Does not cut itA little bit misleading I find both a 290x and 780ti do a perfect job at 1440p and I run all the settings at max. I think the occasional unnoticeable drop below 60fps is more than acceptable especially as it is in generally poorly optimised games.
For a gamer who plays games and does not constantly watch fps counters either a 290x or 780ti is perfect for 1440p and tbh I would save a few quid and go 290 or 780. Both of which still do a superb job.
My view on the Term "max" in this situation is not the same as yours gregster sorry.
Mine is where the Detail's options are all at their highest, yet AA applied to make the Image IQ right for the game.
In BF4 2x AA is the most required(For me)
in Crysis I didnt need it but when i went xfire i added it for the lols
Fixed that for youGet 780Ti, stay away from geforce experience, optimise and enjoy gaming!
Get 780Ti, stay away from Geforce experience, optimise and enjoy gaming!
Fixed that for you
I think the OP should save some money and just get a 290x or a 780ti and save the rest of the cash.
Im sure for 90% of titles either card will be fine at that res. For the others, just lower the settings a little. I know it's difficult (Im much the same) but at that res I think your have to swallow the pill sometimes.
Yea But in that case Nothing can play Crysis 3 at Truly Maximum settings.The problem with those statements though is interpretation. I am sure that you are happy with the IQ on your settings but that doesn't give a true reflection of the term "Max settings". If I ever put "Max settings", that means the highest the game allows and nothing less. Any other settings lowered wouldn't be "Max settings" and i would put something like:
Crysis 3 plays well for me at 1600P with max settings but with no AA.
That way people can see what they could potentially expect to achieve and having a constant is best. Maximum settings is to me what is says (maximum settings).
