** OcUK EXCLUSIVE: SUPERFLOWER POWER SUPPLIES NOW IN STOCK!! **
I wish someone could try and see if the corsair series sleeved cables would work??
Unless the 1200w is different to the 1000w, the connectors are completely different.
vs
this might sound a stupid question but new to building but im about to get the 1000w plat one and dont like the pcie cables, can i just add extensioms to the ones that come with the psu plus also the 24 pin connector as i want to get some braided coloured ones.
Yeah you can use extensions fine with any PSU as the connectors on the non PSU end are standardised, I use Bitfenix alchemy ones :)
Got the SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - White and I'm loving it so far. Well worth the money, thanks OC
whens the superflower leadex gonna be back in stock was just gonna order the 750w gold and noticed its not showing :-(
No idea unfortunately, these things come on boats and take months, so our next shipment delivery is probably circa May. :(
Your parent company has the 750w one at £98 inc VAT. Can't they send them to you?
Comes with the nice clear plastic cable ends :)
I have a small and brief question: Do you plan to import the Leadex Platinum 650/750 at any time? I know internally they are quite similar with Leadex Gold but the all white externals really appeal to me.
Thank you in advance.
Just ordered the 1300W Leadex gold. The 1000W version was awesome so i have high hopes for this new one.
