.Whats with all the doubt? all I said is it hit 17mbps once maybe but its stablized around 11/12.
Impossible. Origin isn't accurate.
No but the file actually did download at that speed, ive used speed test and at the moment im hitting about 78mb.
The cab is right outside my door in my new apartment.
I was on 2mb in my old house.
U are not getting 78Mb from FTTC - no way. Because 79999k x 9679% = 77.43Mbps
BT limit IP Profile rate of 77.43Mbps and after overhead and real term of throughput is no more than 75Mbps. (BT, Zen are 75Mbps throughput. Plusnet & few other isp's are 72/73Mbps throughput)
So, you are more likely getting around between 72 to 75Mbps.
Buyer beware on BT Infinity 2 crosstalk is causing DLM to kick in it might take a few months but once it kicks in its almost impossible to get your IP profile raised again.
Look on the official BT forums its the no1 issue right now with no end in sight![]()
I could be wrong but my understanding is the crosstalk is caused by increased congestion at the exchange & BT not yet having an automated system to deal with this so as your exchange or cabinet gets near capacity crosstalk means DLM kicks in & lowers your IP profile (which BT mods on their official forums tell me is very difficult to get BT Wholesale to raise it again so your effectively stuck with what you get as long as its 50-60% within your original bandwidth quote that's itCrosstalk due to the poor copper cable the other side of the fibre?
The second effect, crosstalk, describes the leakage of the signal in a copper pair into neighbouring pairs. “All my neighbours get a little bit of the signal sent on my pair, and vice versa: the signal I receive is not only the useful signal transmitted on my pair but also noise, the contributed components from all my active VDSL2 neighbours,” says Paul Spruyt, xDSL technology strategist at Alcatel-Lucent.
Typical a cable bundle comprises several tens to several hundred copper pairs. The signal-to-noise ratio on each pair dictates the overall achievable data rate to the user and on short loops it is the crosstalk that is the main noise culprit.
