Yeah Meteor still seems a bit crap. Its too expensive and there are far easier skills to land for greater effect.
I found cold-centric builds still fairly effective even before Frost Orb but until my early 40s I was still playing Normal. I only switched to Expert after beating it the first time. May not have had the same effect on higher difficulties before that point.
That said I did have a bit of fun with Blizzard, 80% slow, Frost Nova, 900% damage rune and Ray of Frost massive damage DoT on enemy death. Problem is the harder things get, the less it matters how easily you kill the mobs. Its down to how you can handle elites and champions and some skills simply don't work very well for them at all.
Emeralds are worth like 5-6 times as much as Ruby's so your friend is doing you a huge favour there!
[ui]ICEMAN;25956300 said:Marquis and higher gems drop from mobs in the xpac anyway so I wouldn't invest too much gold into gems unless you plan to sell them before the AH closes. I personally made over 1 billion gold buying flawless square rubies from the AH and turning them into radiant stars about a week ago![]()
What I've been doing is clearing areas of mobs (anywhere high density) or running Torm 3 acts while looking for Keys.
I made over 5 million Gold last night from dropped gold alone (Goldskin armour with 100%plus Gold find and procing gold drops on hit) and bought gems from the AH and combined them (5 mil bought me around 300 flawless squares).
I am also trading with a freind he gets my rubys and a i get his emeralds.
anyone used cdkeys.com ??
seems to be cheapest D3 reaper ...
Trustworthy
I use this site, and I've not had a single issue with any sites it's pointed me to for the cheapest price yet:
http://www.allkeyshop.com/blog/
http://www.allkeyshop.com/blog/compare-and-buy-cd-key-for-digital-download-diablo-3/
23 euros (£18.8)
Trustworthy
23 euros (£18.8)
did they send you the pre order bonus code?
