Anyone running msi 290 crossfire here? What temps you getting?
Have the cards arrived yet Shanks?
My new MSI 290X Gaming is here!![]()
The first was 90 degrees hot at almost 100% fan speed. The new one has only 82 degrees at 65% fan! In idle silently, under load audible but still pleasant. The MSI is the best card with 290X-GPU for me![]()
The values are from BF3, Crysis 3, Metro 2033 and Heaven Benchmark. My case is a LIAN LI PC-X2000BN with 5x 140mm BeQuiet 900Upm fans.
Undervolting is also possible (-40mv to -50mv) and brings 4 - 5 °
My 290X (stock) in heaven hits ~75C. Though I notice by default mine is on +13mv in Afterburner. It struggles in Tomb Raider, is it normal for it to go above 90C in Tomb Raider? I notice in BF4 it tops out near 80. (all at 1440p).
Worried I have a bad heatsink.
Inside the case (phantom 630, it's really cool with plenty airflow.).
GPU idles around 36-40C. With a video running it's around 49-50C
The guy on the right looks like a b grade dutch porn star. The sort that would come to fix your fridge and end up servicing your mrs at the same time.
I think +50mV is too low for 1200MHz on the core clock.Hey guys, posted this on the official 290x thread but maybe will have more luck here!
I have a Gaming Edition which Ive been trying to stop artefacting at higher clocks. However, when I enable voltage control on afterburner, adding +50mV doesn't appear to stabilise the core at all to get above 1200. Then, as soon as I click apply when trying to go above +50mV on core voltage causes an instant black screen, without trying to add any more MHz.
Has anyone else had a similar problem?
First you need to check what is your base voltage. For example my 290X has around 1,06-1,06V load. For 1200 core, i need the full +200mV in Trixx which gives me around 1,25-1,26V under load. I'd need a tiny bit more to make it 100% stable.Hey guys, posted this on the official 290x thread but maybe will have more luck here!
the refund on my rma of a 7950 has cleared, thanks ocuk for helping me sort that. now to decide which 290 to get. its most likely gonna be the msi gaming edition but im waiting till 9am to see if there will be any daily deals before i order. this thread has been a big help choosing but if the tri x comes in at a lower price today i may grab it.
