Good Cheap Server - HP Proliant Microserver 4 BAY - OWNERS THREAD
9 Mar 2003
26 Dec 2005
Anyone have their microserver tucked away in a cupboard, just checked speedfan and its reporting a core temp of 51C and hard drives at ~32
Is that going to be an issue?
Thanks,
13 Oct 2008
SE London Born and Bred
Thanks,
Mine is in my old airing cupboard, I normally leave the door ajar by about an inch.
Here are the temps over the past two weeks or so.
20 Oct 2008
The rated operating temperature for a HDD is going to be 60+ degrees.
Find the manufacture's specifications and see what your drives are rated at. I pretty sure you'll have plenty of headroom to play with.
The maximum operating temperature for the CPU will be much higher.
7 Aug 2005
I have two Microservers (N36) and am considering using one of them as a HTPC, are they capable units for 1080P playback via XBMC (OpenElec)?
I would be purchasing a Radeon HD 6450 low profile card.
9 Oct 2007
Mansfield, Notts
You want a 3 pin fan and just cut one of the lugs off to make it fit, some one will tell you which one to cut off, the 4 pin header on the HP motherboard isn't a standard pwm so you have to also modify a 4 pin if you use one of those.
