Caporegime
- 9 Mar 2006
- Surrey
Looks like two of them are pre patch and they've renamed and retooled the set.
Installing this again. Not played since release week as I thought it was very poor but thought I would check it out again.
This is what I'm thinking, but what has changed exactly?
no error #37![]()
ERROR 37?!??! what are the other 36 errors?! this should be number one not getting into the ******* game!
New difficulty levels, new loot system, no more paragon cap, new events and the auction houses are closing down. Blizzard have actually explained it very well on their site, and they have also brought in a 50% increase in experience/loot till the expansion is released.
I'm at work so couldn't check, but pretty sure it says both when you mouse over it in game?
Reaper of Souls™ launches on March 25 for PC and Mac—and as of today you can prepare for death's imminent arrival with +50% bonus XP in Diablo III.
This hefty XP bonus gives your heroes a leg up on the new Paragon Leveling System, which just went live in patch 2.0.1. The new Paragon Leveling system not only allows ALL of your characters to share and contribute towards a single account-wide Paragon level, but it also grants bonus ability points with each Paragon level gained, which can be discretionally assigned to your character’s stats.
I would make a new Wizard and start on Normal or Hard mode. Play through the game again from scratch and find some upgrades with all the nice drops you'll get as you play
Playing from your existing Level 50 may be OK, but much less interesting I would have thought.
start normal for the first 10 then hard it up didn't really notice the difference between normal and hard but it was worth a re roll
I started a new toon with the loot 2.0, i already had DH, Wiz, Monk and WD at 60, only toon i never had was a Barb, so i rolled one of those, mainly because Crusader gear is similar and i could use the Barb to farm the crusader some gear, hopefully crusaders can use 2h as i found a legendary 2h with -20 level on it, and 1250dps or so, not bad for a lvl40 2hoh and it has a socket
