Man of Honour
- 8 Nov 2007
- Outer Space
Good job on the orange accents
Yes I think orange LED's might be a bit much. Orange sticky back plastic film will do the job and wont void any warranty as it could be removed. This sort of thing:
It would involve a lot of cutting to size for each connector and might require 2 or more layers to be really orange but I think would look amazing?
You can get a roll for like £2 so why not give it a pop![]()
So tempted mate but think it will be a ball ache. The nature of them, applying it would be a nightmare. Much easier to mod the LED area. Might look into it but wouldn't want to loose my warranty.
Thanks for the idea though! Will keep you updated after abit of Googling on modding a superflower - hopefully someone has done this before.
Well if it's just swapping LEDs it's simple enough, very low risk, or very high risk depending on your soldering skills.
I suppose it boils down to your skill & how much you think you'll need the warranty. Superflower's a good make, might never need the warrenty
aaaah, right, I'd say no too.
Looks like a smart wee setup in there, it'd take destroying one to check but I suspect they're PCB mounted, so magnifier + fine tipped iron and a good number of hours for a small gain in the effect.
It's starting to look real beastly...
Thoughts:
That stupid PSU sticker has to come off or be covered!
You could place something black (hard sheet of plastic or something) over the sticker on the PSU, and make sure not to put any glue on the actual sticker itself (just around it). Then there'd be no problems with warranty (just clean off the glue around the sticker and it's good as new). Maybe even write a name (in orange) for your build on the black plastic.
As for the PSU LEDs, if you don't fancy the sticky plastic idea, go for a Transparent Orange Acrylic (also called Orange Tint Acrylic) mod. You could snugly surround the connectors with 4 pieces of this acrylic (or a 3D-printed UV-cured acrylic plastic single piece made to size).
nice colour scheme, need more orange!
So I decided to overclock my GPU tonight and not much luck - If any of you guys have an experience with overclocking It would be great if you could help out on a thread I just created in right section:
http://forums.overclockers.co.uk/showthread.php?p=25990219#post25990219
Yeah I've got the same card as you now and have had great results overclocking, I have posted a response in your new thread![]()
Build is looking great, the orange accents real make it stand out.
From the looks of it the gain for changing the led's for the PSU isn't worth the cost and time needed. If it's even possible at all.
I'm going to get round to doing the other hard drive cages this weekend I think. Regarding the PSU, I think if I do mod it, will be the last step! Definitely the most fiddly part.Regarding the PSU, I think if I do mod it, will be the last step! Definitely the most fiddly part.
I don't think covering the connectors in orange film would be that difficult. I was bored at work and downloaded your pic of your pc and changed the LED colour to orange using paint.net:
CMON you gotta try mod it!! This is Overclockers after all!
Now, I know I was a neigh sayer before, but can't argue with those results![]()
This build is sweet! I'm saving for my next build and I'm taking some inspiration from here if you don't mind![]()
Just a thought:
1. changing surface mounted LEDs isn't that hard if you don't care about the old LEDs.
2. maybe swap the connectors with semi-transparent orange ones and leave the lights?
Just a thought:
