http://www.screwfix.com/p/prysmian-6242y-twin-earth-cable-1mm-x-100m-grey/20999
Way more copper than a home speaker will ever need, pure, and bends to shape and stays there.
That certainly looks a good bet for home, loads there for not much £££
Most gains people experience from changing speaker wire is more than likely due to a re-tightening of connections and using fresh non corroded wire which will lower cable resistance. A quick re-trim of the existing wire and a tightening of connections would more than likely produce similar results.
Cat5e.
Google FFRC Cat5
Most gains people experience come from the fact they've spent far too much money on something and need to justify that cost to themselves.
As an electrical engineer who has spent far too long looking at signals and scope traces and other things, for speaker cables, two things matter.
1) Is there enough copper to carry the power you need it to.
2) Is it easy to install with/does it look nice if you can't hide it!
%100 agree.
My front speakers are connected with Van Damme cable my rears are using the Cable-Tex cable. Both front and rear speakers are the same. I can tell no difference at all at any volume between the two.
Skin effect isn't really an issue at audio frequencies, so using cat5e as a kind of pseudo litz wire is fairly uneccessary.
They also fail to point out that an average speaker has a considerable amount of internal wiring in the coil and also the internal wiring of the amplifier should be considered but never is.
Rainforest
Cable-Tex 42 Strand Speaker Wire
I've had Van Damme and QED in the past. Save your money and buy this. It's brilliant
^^^this
people can recommend the latest Van Damme, Jackie Chan, Bruce Lee, whatever cable when ordinary thick copper cable will do
Stuff
But it's dirt cheap and perfect for carrying a signal. No need to spend hours braiding it. I've just done some rough braiding to keep it together when running it though the flat. Solids going to +'ve terminal and striped to -'ve. 2x15m cables, 2x5m cables and 1x2m cable got made in under the length of Blade Runner.
There's a few alternate versions where they strip each individual wire out and then braid those together. No thanks.![]()
As far as capacity goes for those folks who like to shout about premium speaker cable capabilities. This stuff is designed to carry multiple streams of HD audio and video content as well as various over air services all at one time
