It's really worrying to be completely honest. We're living in a world where they spend billions of our hard earned cash to launch global eavesdropping missions to "stop terrorism", yet one terrorist who's a qualified pilot is all it potentially takes to make a fully laden 777 completely vanish?
OK a cargo liner I could understand, but a passenger jet? FFS there should be over dozen redundant self-deploying beacons with their own flotation devices located along the entire length of the fuselage including several in the tail section.
What makes these 'self-deploying' beacons and floatation devices deploy?
We still dont know for sure that it crashed.
That's even more worrying. 200,000KG object worth three-hundred-million dollars flying around with effectively a cloaking device?We still dont know for sure that it crashed.
I'm struggling to get my head around the basics of this whole story:
Surely if the following items exist today:
Self-inflating flotation devices
Various types of distress beacons
Then how is it possible to be in this situation where a commercial jet liner has simply vanished?
Merely active/transmitting during normal flight. Deployed upon severe G-force or water immersion.
That's even more worrying. 200,000KG object flying around with effectively a cloaking device?
I am still leaning towards the rapid decompression. The pilots fell unconscious and somebody, probably a crew member tried to raise the alarm but lacked the knowledge and turned things off.
The crew, somehow awake after the pilots fell unconscious, entered the locked cockpit, and fiddled with switches they didn't understand, before failing to secure an oxygen supply, and falling asleep themselves? I'm no pilot but that seems... completely implausible.
However, it was determined that a body found in the cockpit area was that of a male flight attendant[citation needed] and DNA testing revealed that the blood on the aircraft controls was that of flight attendant Andreas Prodromou, a pilot-in-training with approximately 260–270 hours of training completed. He tried to save the plane; he called "Mayday" five times, but the radio was still tuned to Larnaca, not Athens
Were playing the conspiracy card though, most likely it's crashed into the sea and sunk.
de (but that if they dropped altitude it would be less fuel efficient).
That's over 8 hours of fuel loaded in the tanks... for what should be 5 hours 21 minutes flight?
<Tin-foil hat mode>Is that the normal amount of safety-cautious reserves for emergency diversions/weather avoidance? Or did the Captain request more fuel because he's got a plan?
Why most likely? It's been taken deliberately and someone has put a lot of hard work and planning into it, clearly. You really think with all that preparation it would end up in the sea? No, my money is on it being intact somewhere, and being taken by the pilot.
You've got no proof of any of that. And you've said aliens did it+other ones.
What could they need it for?
You would also need a large runway miles away from anyone that might see it come it to land.
http://www.independent.co.uk/news/w...-and-how-can-a-plane-just-vanish-9194501.htmlWhat runway length would a 777 need to land?
Given that it would have been almost empty of fuel, a mile or so would suffice – less than half the length of Heathrow’s shorter runway.
They would only need a mile stretch to land, and flying over remote areas of the Middle East there's more than enough room.
The emergency oxygen supply in the passenger cabin of this model of Boeing is provided by chemical generators that provide enough oxygen, through breathing masks, to sustain consciousness for about 12 minutes, normally sufficient for an emergency descent to 10,000 feet (3,000 m), where atmospheric pressure is sufficient to sustain life without supplemental oxygen. Cabin crew have access to portable oxygen sets with considerably longer duration. Emergency oxygen for the flight crew comes from a dedicated tank
