They would have been taking a round about route if you take the inmarsat locations into account though, which are the last (currently) known locations.
Why would two Iranians steal a jet to go back to Iran, somewhere they had just come from? If they were going back to Iran then they would have to land somewhere, which could indicate some state involvement.
QQ from me. How do they know the last radar tracked position was that of MH370 and not something else unidentified. Are these "pings" theories accurate now?
False flag attack by the US to draw China into a war against islam. ..
Muslims don't need the US for that, they're already doing a fine job on there own, the last attack, killing 28 people by knifing them at a train station was pretty grim.
But I am surprised at the Chinese lack of response at that
The inmarsat locations are only a vague plot based on signal strength and time elapsed
and adding in other factors such as directions they couldn't have continued on for prolonged periods without highly likely being detected and other possible (unconfirmed AFAIK) military tracking suggests that a north west destination is one of the most likely
while Iran is an outlier the presence of Iranians with stolen passports tends to lend credibility that its a possible outcome
and while some sources (again AFAIK not confirmed as factual) claim it only had enough fuel for approx 2-2.5k subsequent miles that seems low for its flight plan - those 200ERs do the flight from Singapore to Sydney non-stop no hassle so assuming it had a fair amount of fuel its completely within the realm of possible to do Iran without landing mid-way.
Assuming any of this is at all on the money or true the reasons as to why would likely be even more complex - but likely to be more than just an irregular hijacking or someone wanting to steal the plane. Before any other theory would need to know in detail just who was on the plane of any significance.
Yet there were 160+ Chinese, several westerners and many malaysians. The plane could have flown over China according to the Immarsat plots. If flying to Iran the most direct route would be either over India or south of India, a comparable distance to the northern route but with far less chance of discovery. Why not fly that way if Iran was the destination? It was apparently well planned so would have made more sense IMO. As for the passports if they were part of such a well coordinated plan you'd think they would use passports a little more difficult to track.
Just out of interest, if someone was able to pull the breakers on the transponder etc, would they not also be able to pull the breaker on the flight recorders too?
This would mean that even if the plane was found, we may still never know what happened.
You wouldn't need to pull the breaker to disable the Transponder. You would use the off switch![]()
The standby switch![]()
It's more of a position on a rotary than a switch![]()
Who orders the fuel. I'd assume its the pilots responsibility. He will tell the ground crew how much fuel he needs. Obviously if he order 20 tons too much that may flag up. Unless he doesn't declare correctly how much he already has on board.
