- 15 Feb 2012
Fire burning for 4 hours on the plane, that's not physically possible.
Except in the normal operation of the engines... right ?
I also love the idea that a pilot sitting at home with Google Earth can solve a mystery which 25 nations, with far more information than we have, can't. Seems ridiculous to me.
Yet the idea of people on the internet with no knowledge of planes suggesting stupid theories makes more sense?
Not lost, but gone... gone... forever...So you think it's, Lost?
Just sealing the unit at the time of manufacture with argon instead of air inside it. Argon is quite a common gas used to prevent fires, any server building for example will use argon gas for fire suppression..
It does make sense - also, he posts a further comment at the bottom explaining the new data regarding flight routes;
From hades post:
Fire starts in transponder wiring. It goes off. Pilots unaware.
Fire noticed shortly after the handover call.
Pilots pull fuses.
Head towards nearest airport hence left turn.
Climb to 45k to try to starve the fire of oxygen.
Fire overcomes pilots or air starvation puts everyone to sleep.
Plane descends irratically not in control and then flies on for several hours.
Plane eventually crashes into the sea several hours later.
What about the period where it flew at 5000 ft? And during all this time no-one in the plane made a phone call. I still don't buy it.
I agree - The quick climb up and also the dive is typical of trying to put out a fire - it does seem very likely that this scenario is the correct one, rather than a hijacking type scenario.
Also, has it been confirmed that passengers phones were still ringing 24hours+ after disappearance?
If so, plane crashing into sea wouldn't really make sense?
They looked into that and found that with so many carriers and roaming networks the phones would ring at the caller's end even if off.
And how does flying due west allow the plane to intersect the arcs? He didn't explain that and neither have you.It does make sense - also, he posts a further comment at the bottom explaining the new data regarding flight routes;
From hades post:
Pilots pull fuses.
The problem now exists of, where along this line is the plane and why has it taken 10 days to get to this point - if anyone had survived the crash (all be it unlikely), they certainly wouldn't have survived 10 days with little to no rations and potential injuries.
