Hi Guys
Corsair have today released a superb addition to their range, the SPEC-03 is an affordable gaming chassis that offers great cooling performance and high end features at a great price point.
This case is perfect for a budget gaming system and provides all of the cooling mounting points to allow you to expand and upgrade your system with performance AIO coolers and extra fans for superb airflow.
Corsair Carbide Series SPEC-03 Mid Tower Gaming Case (CC-9011052-WW) @ £45.95 inc VAT
The SPEC-03 features an industrial, high-airflow front panel, a huge windowed side panel and a front 120mm LED fan. Add to that our USB 3.0 and native, tool-free SSD and HDD installation and you can have your killer gaming rig up and running in minutes.
Most cases at this price point don’t give you the combination of great looks and great features that the SPEC-03 does. Up to dual 140mm front intake fan, an rear 120mm exhaust, and room for massive graphics cards makes the SPEC-03 stand out among the crowd.
Product Features:-
- Tons of fan mounts:
- Front – 2 x 140/120mm (1 x 120mm LED included)
- Top – 2 x 120mm
- Rear – 120mm (included)
- Bottom – 120mm
- 2 x USB 3.0 front ports with internal connector
- Large side panel window
- Cable routing and CPU cooler backplate motherboard cutouts
- Seven PCIe slots with room for long graphics cards up to 426mm long
- Install up to three 3.5” and two 2.5” drives simultaneously – tool free.
- Dust filters for front and PSU intake.
Box Contents:-
- Carbide Series SPEC-03 Mid Tower Gaming Case
- Accessories box with screws, zip ties, and other mounting hardware.
- Warranty and Support Information
Specifications:-
Product Dimensions: 445 x 185 x 440 mm
Shipping Dikmensions 558 x 246 x 474 mm
Only £45.95 inc VAT.
ORDER NOW
Product Features:-
- Top – 2 x 120mm
- Bottom – 120mm
Box Contents:-
Specifications:-
ORDER NOW
