- 2 Jan 2012
- UK.
I've had both. Prefer the GTX 780ti. Imho it's worth the extra.
If I go with the GTX 780Ti iChill , would I be able to SLI them with a 1000w power supply and a Maximus hero mobo?
Or would I not have enough space/power
Have to agree, the 780ti is such a better card ihmo. The r290x is decent 'bang for buck' card, but that is at the cost of it running a lot hotter and the fan spinning up a lot louder to try and keep it cool. Even with a decent fan curve, it'll run into the 90's easily with demanding games.
I went from a MSI Gaming 290x to a reference 780ti (now two). Even with SLI, both cards are much cooler and quieter than the MSI Gaming r290x.
You can get this Sapphire TRI X 290 card for £320. That will be as fast as a 290X (if you overclock it to 1050/1250 - which it will do easily) and comes with the best air cooler out there in the 290 range.
http://www.overclockers.co.uk/showproduct.php?prodid=gx-348-sp
they are nice for sure!
but can i ask what res you are playing at
http://www.overclockers.co.uk/showproduct.php?prodid=GX-348-SP
