Caporegime
- 13 May 2003
- Warwickshire
My grandma brought me some beans back from her trip to Hawai which means I have to take the plunge and buy a grinder. As I wont be using it daily I think a hand grinder will be fine.
It will be mainly used in conjunction with a Moka pot and occasionally a french press, I know there are two hand grinders that are regularly recommended on the forums, the Hario and the Porlex.
The question is, for my use case is there an obvious choice or are they both as good as each other? Also they seem a lot cheaper on Amazon but seem to be imported, I take it that these are trustworthy?
Thanks in advance![]()
I've got the hario skelton and find the grind quite inconsistent at a given setting. It's well made and it grinds smoothly, but you seem to get a huge variation of grind coarseness in a batch.
I can't speak for the porlex.
Incidentally I received an aeropress yesterday and it's a fantastic piece of kit. Much smoother than my french press, and no grit at the bottom of the cup either.
It reminds me when I used to have a big mug of coffee from my cafetiere.. used to get a big caffeine hit. I've just had another double with milk in my 5oz cup and I'm not feeling much at all.. I guess it just must be me
Problem is, with that americano i made, it was absolutely tasteless
