Hitman Bench Thread
Caporegime
12 Jul 2007
United Kingdom
Well i'm only 8fps off Matts single 290 score so not too bad of a result :D
I think you can do better with some tweaking. Get your cpu clocked up to 4.8ghz and experiment with your clocks. I think there is perhaps more to be gained from your setup. Maybe try moving the memory up in 50-100mhz tweaks until you find that point at which performance drops.
30 Jan 2012
Stoke On Trent
Well tbh since i updated my BIOS before xmas i lost my 5GHz overclock profile and didnt bother to set it up again. I'll set that back up when i get time then give this another run.
I should be able to pull off 1250 core on my 7950.. I ran 1225 earlier and it seemed to run ok except for the memory clock throttling.
25 Nov 2011
The KOP
1080p
i7 2600k @4.4
Crossfire R9 290 @ 977/1250
14.3 beta
avg 78fps
Caporegime
12 Jul 2007
United Kingdom
Kaap is the master at bench threads, that's why i asked him to start this one. He would do a much better job than i could. Can't fault his layout. Here's my scores.
2700k@5ghz
290 Crossfire @975/1250
14.3 Beta
1080P Single Card
1080P Multi Card
1440P Single Card
1440P Multi Card
Crossfire Scaling
1080P - 76.6%
1440P - 90.4%
1080p
i7 2600k @4.4
14.3 beta
avg 78fps
Your score looks a bit low. Ours should be similar. Mine will be ahead because of my 5ghz cpu but even so you should be higher than that. Did you have +50% set in powertune and have ULPS disabled?
Caporegime
12 Jul 2007
United Kingdom
Going to remove these 14.3 and give them another install.
Just speaking with shanks via email.
Difference in our systems are
CPU - 4.4ghz vs 5ghz
Memory 1600mhz vs 2133mhz 9-10-10-21-1T with tight seconds and thirds
MOBO x16 x8 vs x16 x16
I expect the cpu plays the most part, closely followed by the ram and lastly the pci-e lanes. Either way, quite a big difference between our scores whilst using the same driver. :confused:
22 Jul 2012
London
Please try not to beat my dual gpu score with your water cooled 290's. Let me have my moment in the sun. :p
Wouldn't worry too much. I get around the same clocks as you anyway. Trouble is, the 2600k on that rig will only go to 4.6...
Updated score (barely):
1080p
7970CF @1280/1850
2600k @4.7
13.12
81.2fps
Single card run @same clocks
49.1fps
Cba to clock the cpu to 5ghz...
