Caporegime
- 8 Jan 2004
- Rutland
Would you mind casting your eye over that F10 above Fox? A reasonable buy?
[TW]Fox;26070084 said:Seems so, as you spotted mileage just low enough warranty wise too.
The head up display is a fantastic though rare option.
[TW]Fox;26070066 said:Pro nav isn't just sat nav it's a much better screen etc.I would leave off stuff like folding mirrors and run flats (why would you voluntarily pick those) to free up budget for pro nav.
Agreed Pro all the way
*Nav
*Traffic updates
*internet
*weather updates
*larger screen
*DVD player
*Black panel
Check youtube for a detailed look at the features.
Business Navigation ...cost £990....increase in GFV £510..........cost £10.75 pm.
Pro Nav Package.......cost £1990...increase in GFV £637..........cost £29.75 pm.
So an extra £1000 spent gives you an additional £127 in GFV.
I'll take 10 please![]()
The larger screen is nice to have but the rest is useless in my opinion. Who checks the weather and uses the internet in their car?
Black Panel Display is £125 and worth going for.
The runflat tyre option is free so there is no finanical saving by not choosing it.
Elec Folding mirrors - nice to have, but £275 when you can do it yourself. Unless you want the auto wing mirror dip when you select reverse.
How are you buying this car?
- If leasing then Pro Nav is probably not worth paying for as you won't get anything back when you hand it back.
- If buying outright or financing in full then Pro Nav might be worth going for, for the re-sale value later on.
I'm doing this all under PCP and intend on changing every 3 years. I know the Pro comes with the little extra's but i asked myself do i need them and i don't.
Thanks for the opinions so far
[TW]Fox;26071324 said:It's Sophisto Grey Xiriallic isn't it?
