I figured overclocking issues were the same for everyone? Crashes, garbled screen etc, I thought I'd be adding too much to an already long post by including what was already known.
You need to be a little more specific about what you are asking.
For example it is hard to check you 3dmark11 score without you posting the link and also stating what CPU and clockspeed you were using.![]()
Are you just looking for an argument Ranger ? It seems to me that all you're doing is trying to stir something up ?
I came on here looking for a bit of advice and all I get from you is some kind of power struggle attitude. There's nothing like a know it all to ruin an atmosphere on a forum, It's no wonder I stay away from forums. If it bothers you that much then simply don't answer my questions.
Best place to get informations is on forums mate.
Some people forget that at one point in there life, before they were good, they were also noob.
Too true mate, I admit openly that I'm a noob to this stuff. I've only just got back into pc gaming so I need all the help and advice I can get.
Well I got the link to the 3D Mark 11 Extreme score here : X9414
My rig is the Infinity Tesseract, a i7 4770k OC to 4.7ghz. Using 8GB Team Vulcan 2400mhz. 1GB Samsung EVO SSD. Windows 8.1. Anything else needed guys ?
That was my best score so far and with some slight glitching I dropped the settings down for each option, GPU and Memory and I'm getting around X9200 with these settings here :
GPU Clock 1100
Memory Clock 5300
VDDC Offset 31
Power Limit 5
I played AC IV Black Flag and DTM experience for about an hour each with those settings and everything set to the best image quality. I got no 'crashing or glitching' issues with this setup and I plan to use this from now on unless you guys would advise against it ?
When I set the VDDC higher than 150 I start to get issues but I've seen a few screenshots of the S-TRIXX where people seem to use 200 quite often.
Erm GLITCHING AND GARBLED SCREEN as mentioned already in the post that you quoted yourself.
If that's what its called then yes, it's like a bunch of coloured garbled glitches that take over the image, resulting in a crash if I leave it on.
so if you overvolt without overclocking you still get this issue?
Couldn't agree more![]()
No, I haven't tried that without an OC on the cards. I generally have the GPU on or around the 1100-1200 mark, the memory around 5400 but the VDDC is where I get confused. If I set this high it will start to give me those glitches, even higher than 70 when combined with the OC settings above.
The closer I keep it to around the 40 or 50 mark, the better it seems to cope. Is that an expected outcome ?
Thanks for the advice by the way.![]()
Really?
Its funny you say that because i dont see any of you helping out.
Because you are the pro Ranger ! And you know you are good, but sometime, you have to leave the condescending attitude aside.
________________
Papalu, what type of cooling do you have and what kind of temperatures do you get under load, you can verify those values with GPU-Z. There is a sensor tab.
There's Digging for information with a pick and there's asking nicely, I prefer the latter as that's the way I do it.
Anyway lets forget all that.
Refresh rates are 60hz so no issues there.
You said : if you lower your voltage but not the memory your memory will become unstable which will cause a crash or horizontal flickering
I did notice that if I went lower than around 10 on the VDDC that I'd get those glitches again. But going up past 70 or so would have the same effect.
BTW I've only just started with this, I've got a motherboard to overclock next![]()
Quote me on the condescending part. I was ONLY asking for specifics. Wouldnt go as far as saying im pro.
I would say you are pro
You really know your **** . When someone is Top 50 on 3dmark with single card on water... I call this pro.
