[DOD]Asprilla;26076415 said:You are either in the right gear or the wrong gear.
If you are spinning too much then shift up. If you are pushing too hard then shift down (or stand up) until you are spinning sufficiently to sit down again.
The small ring at the front is for going up steep hills and the big ring is for everything else.
Simples.
Edit; congrats and enjoy.![]()
I think the main problem was, I didn't have my Garmin. I usually look at that and try to keep around 100rpm. This is the slowest afternoon ever at work
