 - 25 Apr 2010
 - Ipswich
So it does it at low loading too? hmm.
It could be the GPU's but the fact that both of them do it makes that a bit hard to believe, you'd have to pretty unlucky to get two of them with the same fault.
Have you tried running something Prime95 to test if your system memory is stable? faulty memory could be causing the graphics driver to crash.
Il do some more extreme load testing tonight to rule out anything other instabilities just in case.
I fear if will be of no use, I've been happily gaming away this past week with no issue since the cards were removed.
This whole situation has been bizarre.
