so basically this shows that 2 titans arnt enough .
another 3d monitor tech all over again ready for the dustbin![]()
Not at all. You don't need all the AA on and could get playable frames on a single high end card with decent settings.
I've never seen Apple's displays with dynamic contrast ratio… It's fixed. The thick CCFL's were roughly 700:1 and the current LED are 1000:1.
Dynamic contrast would be very tiring on the eyes.
Back on topic. I have been doing some single card testing.
Done 2 games and aiming for that 60 fps magical number and on a single card, it is surprisingly easy. AA sure is a crippler on performance and in honesty, the 2 games I have tested, it isn't that noticeable from on to off. If you are in a static image, you can see edges when it is off but they are very very faint and not at all off putting. I don't tend to stand about in games as well, and moving about is fluid and smooth.
Anyway, so far on a single Titan (at stock clocks) and a 3930K at 4.625Ghz:
Bioshock infinite
Ultra - 21 minimum - 50 average - 77 maximum
Very high - 30 minimum - 50 average - 74 maximum (no idea why that is)
High - 31 minimum - 63 average - 95 maximum
It is worth noting that on high settings, it looked just as good as ultra but came with screen tear and would need V-Sync to be applied to stop it. The game was smooth on ultra but those minimums could be an issue. I would run the game on high with V-Sync enabled and it will be a great looking game which is very smooth and very playable.
Batman Arkham Origins
Ultra with 8XMSAA - 19 minimum - 23 average - 52 maximum
Ultra with 2XMSAA - 31 minimum - 40 average - 49 maximum
Ultra with 0XMSAA - 44 minimum - 57 average - 73 maximum
On the slow moving scenes of Batmans in-game bench, slight edging could be seen with AA off but this needed to be looked for and on the faster moving scenes, it looked just as good as when 8XMSAA was used. The game was very fluid with 0XMSAA and for a single card, this is ideal. No tearing and nice and smooth.
More to follow.
I currently have an MSI GTX680 Power Edition and considering upgrading to a 290 (not X version as funds are limited).
Would a R9 290 handle 4K you reckon? Im not too fussy about AA just being able to play at native res.
290 is a stones throw from Titan performance mate, Greg's results will be pretty much what you'd get +-5%.
Have they sorted the FOV yet?Awesome, that might just make me pull the trigger then!
I principally play online fps like BF4, COD:Ghosts and Ill probably buy Titanfall when Im back from holiday. Any of those games you could test at 4k online Greg?
Not kept up to date, but played 1 match and couldn't change my FOV so uninstalled. Playing with anything less than 90 gives me some pretty bad headaches.
I have done some SP in BF4 (can't get online and getting server and game mismatch), so that will have to do for now. SP on the mission where you need to get to the Valkyrie and you jump in the boat and get to where the valkyrie is on fire (Very demanding).
With everything maxed
Frames, Time (ms), Min, Max, Avg
2204, 71761, 16, 42, 30.713
With everything maxed and 2XMSAA
2890, 66394, 26, 66, 43.528
With high settings and no AA
3807, 68765, 47, 68, 55.362
With medium settings and no AA
5683, 73196, 51, 105, 77.641
Can't comment on the game though, as it was a stutter fest but you get an idea of what is what in frames.
Hmm not too shabby, this was with only one Titan right?
I couldnt actually tell you. Ive always had mine at default on all CODs and it works for me! My scores/K: Ds dont seem to suffer! Ill have a look when Im back home on Thursday though![]()
Yep, one Titan and at stock clocks.
So a 780 or 780Ti wouldn't be far behind? So 2 780's or 2 780ti would be just fine? What was the vram usage like?
Yep, 2 780's or 2 780Ti's will be fine.
I am going to do a piece on VRAM usage before I go to work at 10pm or tomorrow if I don't get it finished.
Cool. Would like to know this. If it's way over 3g those new 780 6 gb vrams might be worth buying. I'm not going 4k yet. I have a 1440p monitor, but I might go 4k in a year or 2. Just want to know where I stand in the vram department![]()
