Windows 8.1 Update 1 arriving on March 11
With the update(s) applied, the all apps screen now groups alphabetically taking up more space. Does anyone know how to remove that grouping?
Updated for the mu zip. Painless update took 15 minutes. KB2919442 already on system from last month. Four restarts and we now have version 6.3.9600.17031.
Had the update from last month - so all were already installed except for KB2949621 the last update in the list. All running ok, but my version shows 6.3.9600 without the 17031, but all ok I presume.
Painless otherwise.
Mark
Painless otherwise.
Mark
You'll be ok.
AIDA64 gives that build info or you could use regedit to look at key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion
I decided to hold back with the update last month until it appeared on MDSN.
<SNIP>
EDIT:
File Name: en_windows_8.1_with_update_x64_dvd_4065090.iso
Languages: English
SHA1: 4652DC6EBFEBE02C6A63E167C36E3FAEDFB93999
Code:
https://drive.google.com/folderview?id=0B1huEBZdd47ccWMtakhfcDlxS28&usp=sharing
Code:
http://torrage.com/torrent/EDF9E874C70071203DFA7B3844DDA6CDCFC4C401.torrent
File Name: en_windows_8.1_with_update_x86_dvd_4065105.iso
Languages: English
SHA1: 54B8572556B316A6BECE54C5033564E3296F5951
Code:
Code:
http://torrage.com/torrent/BBC17FEB235417FC8F252A82CCA2CD50F20D16CA.torrent
Thanks!
The x64 patch is:
mu_windows_8.1_windows_server_2012r2_windows_embedded_8.1industry_update_x64_4046913.zip
EDIT: Hash 6A5CBC6FD6C1366F1041E03820FD8508FC95A4AC
Know where I can get this? Want to update the Mrs's 8.1 install.
On Windows 7 (Just installed it last week) at the moment I can upgrade to this update 1 via the .ISO above and it will keep my files but I want to keep my apps too. Is there a way of doing this?
I don't really want to go through the process of installing Steam, Origin etc all over again.
i was just reading this on neowin...
Finally, Microsoft has tweaked it's boot sequence depending on the type of device you are using. If the device has a touch screen (tablet and some laptops), the first boot will be to the modern environment. If your device does not have a touch screen, then the default boot will be to the classic desktop. It is important to note that if you are upgrading from Windows 8.1, your previous settings will be honored and will not use the above configurations.
this is something i said should happen over a year ago...
i do think it should auto detect what hardware is available and default to desktop if there is no touch screen. of course there could be options to over-ride this if people want.
common sense prevails. :p
