Man of Honour
- 5 Oct 2008
- Kent
Meh, one more answer then.
Ah good, well that makes sense, first thing you have posted that does so far.
The "multiple people" you mention are the same few names which have tirelessly defended Windows 8 since release from any criticism, makes the views skewed and unreliable, plus I fail to see the "logic" that sales were high in the first 6 months and this means Windows 8 is a success (it's been out 19 months in total), yet it's "illogical" to use market share with other OSes, including Windows 7 and XP for some reason, when proportional market share does not support the fact that those "high" sales have continued.
In essence because the evidence in particular does not suit your argument (rather it blows it out of the water) you keep screaming that it's "illogical" to use this evidence and then you keep trying to compare it with films.
Actually no. A machine with 1GB RAM can be perfectly useable with Windows 7, but slow with Vista. My brother's laptop was slower when running Vista, then he used the upgrade software to upgrade to 7 and his machine has 3GB RAM. Then there's the fact that UAC kept on repeatedly nagging you if you were sure you wanted to install that program you had already said yes to, which Windows 7 fixed, this would give a perceived productivity hit for workers as the interruptions would be more frequent.
The only thing you are right about is that Vista got the brunt of bad rap, due to the way it handles access rights and other changes which were incompatible with older programs and that on top of the speed decrease over XP it was given a (perhaps unfairly) bad reputation, which has stayed with it.
Well done. You can see they are different words, but you're still wrong.
Discussions like this make me think that it would be a better way to get an intelligent conversation.
Yup, still a good year and a quarter of support, they did it that way so companies wouldn't have to be changing their server and workstation O/S at the same time.
ubersonic said:Nope, because it doesn't work that way as logic/common sense should tell you, why do you think you have multiple people telling you you're wrong?
ubersonic said:The difference between 7/8 is actually much smaller than Vista/7, however the speed difference between Vista/7 is in fact quite small, the "perceived" difference was simply due to 7 running better than Vista on the average computer because the average computer spec had improved in intervening years and continued to improve after 7's launch. Vista's sluggishness on it's "recommended" hardware was actually nowhere near as bad as XP's was, and 7 kept Vistas specs and due to some tweaks and the hardware improvements that had come with time it worked better. A machine that was unusable with Vista was just as unusable with 7.
ubersonic said:You mean factually correct, not misguided, they're different words.
You shouldn't type to yourself, people may htink your mad.
