- 25 Nov 2009
Bar keepers friend is something very similar. Brilliant glass cleaner too
Its called Astonish, and its a pound from the pound shop/wilko's, it comes as quite a thick paste, but it works fast and polishes up brilliantly.
Edit - Also need a wheel brush. Wheels are VW Michigan
Wheel Woolies are the best brushes I've used, not cheap mind.
Thanks, ordered. Was only looking at them yesterday.
Is ValetPRO Bilberry Wheel Cleaner still rated?
with that beading and all that saharan dust I bet you had some funkay, brown, camo-esque pattern on the car after some downpours xD
but god damn that is sexy
Anyone used Tuf Shine tyre dressing?
£35 for a kit
Angelwax Elixir for £6.99 and enjoy the savings!
any tips for what wax to buy for a silver car ?
preferably an easy to wipe off wax.
