What sort of quotes you getting.
As I've said before, if you not confident, then get someone else to do it, you can run the ring main & the sockets yourself, then get someone to do the swa, consumer unit & connect everything up.
As for the ring main I start at the work bench & work back to the consumer unit.
, that's to fit & connect consumer unit, install ring main, anything else, must be a very large garage...
