It's not too bad. Gives your leg a bit of a yank and at worst rips a bit off the bottom. You'll be surprised how much stronger your shin is than your jeansGetting jeans caught between chain and chainring whilst riding a fixie would not be fun.
Your flares aren't big enough then. Go back to Gap and try harderI can see I'm fighting a losing battle here with the trouser roller-uppers but I have never in years of cycling caught my jeans between my chain and chainring!
erf skinny jeans and the legs only go to 34 inches so the crotch would probably strangle my manhood.
I don't know how you could be comfortable cycling in skinny jeans
[DOD]Asprilla;26140328 said:Swrve also do fixie jeans with a reflective panel inside the right leg and reflexive belt loops.
Much better value at £80.
they look almost lycra tight on the website[DOD]Asprilla;26140721 said:The Swrve ones aren't that skinny, well not the ones I get anyway.
[DOD]Asprilla;26140802 said:Ah, just checked and it's because I have the Cordura Regular Fit ones. That would explain why they aren't skinny.
Not many folks make a 30" waist with a 34" leg so they are full of win.
Need a couple of cheap tops for the better weather - going to give one of these rumble - for the sake of £15 or something - it's going to be cheap copies but hey ho
http://www.ebay.co.uk/itm/2014-New-...=US_Cycling_Clothing&var=&hash=item4ad0ae5dfb
My 2 tops have arrived today from China. Quick postage.
A quick look at them - will try them on later - and very impressive. Material is a good quality, zip seems fine, all the logo's match up nice, stitching looks good. Will check sizing later but for basically £12 each including postage they look perfect for the better weather. Pictures to follow later.
28" waist and 30" inside leg are hard to find as well.
Anyone used these brake blocks? I'm guessing they're the standard shimano ones that come with any new shimano brakes, in which case the answer is probably that we've all used them at one time or another. I've used kool stops before now, but this is a very good price for 4 blocks.
http://www.ebay.co.uk/itm/4Pair-8-O...sure_cycling_bikeparts_SR&hash=item2c6b463965
8 for £8ish! done a 2k miles on them and I love themdid try all the usual before and none of them match these, the wear might be a little higher(50-70miles quicker than others) but the braking performance is great.
and the price.. oh the price.
wut
£1ish per pad? Blimey. Well, I've ordered some kool stops for this time round, but I'll definitely keep those in mind. What's the significance of the red compound? Is that like the kool stop salmons - better for in the wet?
If your legs are still sore from today, dont do a zone3 ride tomorrow.
A short, easy ride would be better to help recover. Maybe once round your village lap.
