Haha. And who knows if you'd regret it? I suppose monitors are one particular piece of tech I don't get an itch to buy. I get sick of the sight of them sometimes.
"An update on the availability of ROG Swift PG278Q. The most recent estimate is June. As for pre-orders you can be sure that we will prompt you as soon as they go live.
ROG Swift PG278Q features super narrow 6 mm bezels, G-Sync ultra-low input lag, 120+ Hz refresh rate and 1 ms response time. Simply the most advanced gaming monitor to date."
Good cant wait to grab one of these
Just thinking will one gtx 780 ti handle it well if not it will be a expensive upgrade adding another gpu plus blocks and monitor
Some games on full max but not all. And certainly not on ULTRA in the years to come. I'm in the same boat... got my 780 GTX before I got my 1440p. Now to go SLI I need a new PSU too!
Might end up going AMD for this upgrade. Crossfire 290X seems to scale better and result in less frame variability going by recent benchmarks. The 780Ti SLI benchmarks are all over the place.
the whole point of gsync is that it renders frame variability a moot point, the 290X's would need to be 30-50% faster and less variable to be able to equal the experience of gsync, so we are told based on independent people that have seen it first hand
It doesn't make frame variability moot, it keeps that variance from causing frame skipping but can't stop a loss of smoothness. Reduces the impact would be fair.
Though I totally agree that its nuts to go for a gsync monitor and then switch to AMD.
