- 5 Sep 2011
- Surrey
It's not clever putting big volts through things you know, rookie
It's not clever putting big volts through things you know, rookie![]()
Nice going Frosty and knocked those dirty 290X's off from second in 3 card run![]()
Powercolor PCS+ R9 290 @ 1125 / 1450
Phenom II x6 1090T @ 4.1Ghz
http://www.3dmark.com/3dm/2864779
Score: 8990
Graphics Score: 10966
Physics Score: 8104
Yes i know
The question is what?
I would go with an i7 of some sort as they will last much longer. My i7 920 at 4.0ghz is most likely still enough to max out any single gpu card and it's ancient. Can't say the same for the i5 of it's generation. Getting an i7 would probably save you money over time.
Probably best looking at 3770 and above or holding out for ddr4 and the cpu's that come with it.
Its a choice between:
3570K: + 900 Physics Points.
4670K: + 1000 Physics Points.
FX-83##: + 1200 Physics Points.
26/700K: + 4000 Physics Points.
3770K: + 4500 Physics Points.
The only AMD option will cost me the price of the CPU. (£120)
Intel options, all i5's are not of any interest to me.
3770K: New £240 + £100 for MOBO. (£340)
26/700K: Used £??? + £??? for MOBO.
i need to get searching.
