I have been paying for the warranty on my 335i for the best part of 5 years and not a single thing has gone wrong with it.
Having said that my first 911 had over £21k worth of work done under warranty.
[TW]Fox;26085745 said:Modern cars are now so advanced and so complex that I think a decent warranty is part of the running costs now really.
Sods law that the week/month after you stop having a warranty all hell breaks loose![]()
[TW]Fox;26085473 said:I think on the F10 £100 offers the best value.
Where does it say it excludes switches? A switch is definitely not 'trim' so it should be covered.Any one know if a broken switch will be covered? The warranty says it excludes trim and switches but I've no idea ow reasonable the dealers are.
I've got a feeling my E92 335i might have the same issue. I've noticed a loud ticking/clacking noise coming from the exhaust when I start it cold but this goes away once I start driving.
Common 335 problem you speek of. Turbo waste gates both turbos will odds on need replacing and they are an absolute fortune to do.
I'm beginning to wonder if it the dreaded wastegates. It now makes a ticking noise from the exhaust when I lift off the throttle - is that a symptom?
When I mentioned the ticking from the exhaust at start-up to the dealer they had a look at it and said it was probably the butterfly valve in the exhaust and that a rattle couldn't be fixed under warranty.![]()
Snip
For the F10 the options are:
No excess = £1159 a year
£100 excess = £886 a year
£250 excess = £679 a year
Am I alone for thinking it is madness to spend that much a year on a run of the mill car?
These seem crazy high, are they made out of Swiss cheese!
