Windows 8.1 Update 1 arriving on March 11
I just done the latest update to my windows 8.1 machine and now the computer won't even start up. It's asking me to insert system disk :(
Just had this issue after booting up this morning, no time to look at it now though, been working fine for a few days, odd, could be coincidence I guess.
Update: Seems the good old vertex 2, a replacement itself, has bitten the bullet!
I'll try a fresh install tomorrow. Do we still update to 8.1 via the store or did they come to their senses and add it to where every other update comes from, namely Windows Updates?
I don't care how they label it, this is service pack size. Deserves a fresh install imo.
Easier said than done though sometimes, my gaming PC is also the family and my work PC. The amount of stuff I would have to backup means it would be a massive pain.
Seems I might have no choice, no matter what I have tried I am no closer to getting the update to install.
My user folders are all on the D: drive and 2919355 installed fine
No dice in the end. Window Update components comprehensively broken.... Appears it managed to shut itself down before an update completed, according to the logs, and even using DISM scan and repair functions wouldn't fix it. Ended up having to do a clean installation and update post-install.
Relocated user profiles etc before update to 2919355 to test and it worked fine.
I've installed the update on numerous PC's and a couple had issues, on one of them the only way I could get the update installed was to download the 8.1 with update ISO, and put it on a memory stick to perform an in-place Windows upgrade so I kept my Programs and files.
Any major update can cause issues.
I remember recommending SP3 to be installed on XP many years ago and it broke a female friends PC,I did feel a little guilty but then we all know some unlucky users will get an issue or two with WU.
Annoyingly I also cant seem to do an in place upgrade with my copy of Windows 8, the only option I get is to save nothing...
Not really keen on doing a clean install for this one update, seems like there is no choice.
I guess I will put it off as long as I can for now in the hope some other solution turns up.
