*** The Official Diablo III Thread ***
Status
Not open for further replies.
Got this at last :D
Currently farming Act 1 bounties to get Ring of Royal Grandeur which will mean when I do eventually get Inna's I'll get the +250 dex bonus immediately and the main set bonus from only 3 pieces.
Anyone else get a random black screen in game for 2-3 seconds only for everything to be fine again? Rarely happens, maybe once in an hour.
Soooo thinking of buying RoS and want to know if it's worth it.
I had a paragon 100 barb, WD, 50 wizard and a 45 monk before the RoS patch. But was brutally bored of the game. Hows the game now? Is it worth putting the time in, how did the no trading anything turn out?
I'm also consused with Archon with respect to length of it
which effects how long you can be in Archon mode
Maximum Arcane Power or
Reduce Resource Cost ?
thanks
I think the no trading works out a lot better. I actually have to effort into the game now to get decent gear, it is no longer just a case of "oh I need this and I have this much gold, I'll go buy it". Gives a much greater sense of achievement.
How important is +healing for a demon hunter? I've had a few items that give me a small percentage (1-2%) increase in damage and toughness but a bigger drop in healing (10-20%).
At the moment I'm just blasting through bounties/rifts on normal mode. Do I really need any healing? Do I even need it on harder difficulties?
It depends what you are aiming to do and how good you are at dodging damage to be honest. You need as much healing as you need to stay alive and that is a function of your toughness and skill level versus the difficulty you play in.
Up to T3 you can get by with very little even for average player. Higher than that either learn to stutter and dodge properly or stack toughness/healing through the roof.
I can run T3 with 1k healing or so, but I have a well optimised damage set and I know how to play ranged avoidance if needed (finished pre-nerf inferno back in the day)
Not very important at all given you can use the boar if needed in T1 or higher.
Bought this on Thursday not expecting much but fancied some Diablo. All I can say is WOW what a turnaround for a game, now hugely enjoyable and like many people have said its like the old D2. Got through act 5 pretty quick with a Barbarian and unlocked Adventure mode, decided to try out crusader and really enjoying it. Only leveling in adventure mode to get blood shards. So much better with no auction house.
The silly thing is, even though it is repetitive grinding bounties/rifts to gear up for higher torments I am really enjoying it.
I am sat at work thinking about doing some when I get home and tweaking my barbs build. Damn you D3!
Status
