- 10 Apr 2014
- Hampshire
i want to mod my ps4 case to cut a hole and use some mesh over it and a pc fan grill so it will be a lot cooler. what would i need to start this?
dremel, fan, wire mesh, glue?
honestly wouldnt, youd ruin your warrenty.
Extensive Sony R&D no match for a Blue Peter-ist armed with a Dremel, blue tack, chicken wire and some sticky tape.
thanks and it would ruin it but on the bright side, i would only need that for when it over-heats which wouldnt happen with the mod i want to do.
Make far more sense to put it into a custom case than modding the PS4 itself as its got complete EMI shields on both top and bottom for directing airflow. What the OP is suggesting isnt going to be effective - really should look at a teardown...
ps3ud0![]()
So what? If it dies within its warranty period, you get it replaced. If you still feel the need to mod it after that then do so, but voiding the warranty in an attempt to prevent it from failing is just silly.
Sounds like a truly terrible idea. If the heat is actually causing performance issues then get in touch with either Sony or the retailer and get a replacement under warranty. If the heat isn't causing a performance issue then it's not worth bothering. Consoles are very tightly designed, they're not custom PCs that can just be chopped and changed, a 20 degree difference in temperature (which I find to be a bit of an exaggeration) isn't going to improve performance at all. It's not as if you're overclocking it and need to keep the temperature down in order to squeeze out a few extra MHz.
warranty is void anyway, i removed the stickers to look inside
