im not actually touching the fan, im putting a hole in the ps4's outer shell thats directly over/under the internal fans location and fitting an 80mm filter on said location, so instead of the ps4 circulating hotter air, there will be cooler air coming in from outside of it.
i have done fan mods before , 1 on my current ps3 and some to a couple of 360's in the past, i know i have to be cautious.
or just take the whole bottom of it off and be done with it
ps3ud0![]()
Post some pics.
whats with all the negativity? lol
Isn't the fan etc on the underside of the pcb? if so cutting a hole on top will do no good you will have to stand it up
Extensive Sony R&D no match for a Blue Peter-ist armed with a Dremel, blue tack, chicken wire and some sticky tape.
