Caporegime
- 18 Sep 2009
- Dormanstown.
Haven't people been forecasting a better cooler for years? Notably after the 69XX.
Probably but this is the first time AMD have acknowledged it. Just look at the 295x2 cooler and the excellent job it does.
Oh aye, bargain!![]()
http://wccftech.com/amd-talks-coolers-nextgen-radeon-hd-8000-series/
You are quite correct Mart and AMD's product manager for desktops confirmed it but they still used the same cooler.
Point is, if they were keeping it the same they'd have used the 7990 cooler.
Rip off i agree, but an excellent quiet cooling solution and a sign that the next line of coolers will be different.
iirc the same cooler/PCB template has been in use since the hd5800's.
I think the cooling capacity of the current cooler is showing its age so hope amd put some thought and cash behind the next lot of cards.
I agree, but will it filter down to single card solutions at the prices we pay.
I thought the stock cooler was alright tbh, it didn't need running above 50% to stop if throttling (i ran it about 45%), you only need to up the fan speed with a reasonable overclock which isn't really required unless your benching for 1 minute here and there.
If you can't sort your airflow out properly or you have stuck it in a case with poor airflow then thats your problem/fault if you need to ramp the fans up.
What fan % do you run your 290 on greg, or is under water?
)All that says is "We will continue to work together with our partners in alternative, efficient cooling solutions".
That means they will continue to work with AIB partners to produce good AIB cooling designs. Says nothing about changing the reference card at all. Not sure how you can read that any other way.
AMD is said to be working on better coolers for their next generation Radeon HD 8000 series cards according to a report by Computerbase. The site had a meeting with AMD’s product manager for desktop graphics at Computex 2013 who told that AMD is indeed working on a new series of graphics card which would feature better coolers than the ones currently available on Radeon HD 7000 series:
Read more: http://wccftech.com/amd-talks-coolers-nextgen-radeon-hd-8000-series/#ixzz2znB4yqfe
Did you read the same thing as me?
It's all good and I seriously feel for the amount of throttling that will happen when the Summer does hit us for owners of the reference 290's/X's unless they have air con.
The question of whether the half-hearted implementation of the solution provided by AMD is intended to give enough room for their own improvements to the partners, Nekechuck denied emphatically. " In the end it comes to customer satisfaction. If we manage to provide a better cooler is available, the customer benefits. And the partners have to spend more effort to contact their card go one better. "
Works fine for me... But when the wife, who is "trying to sleep through your noisy bloody PC" comes into the room to smack you round the head, you won't even hear her approaching!!never understood the fuss about reference cards being too loud, cheapest option just buy a headset
Works fine for me... But when the wife, who is "trying to sleep through your noisy bloody PC" comes into the room to smack you round the head, you won't even hear her approaching!!![]()
Wccftech are saying that Greg. The actual AMD guy said nothing of the sort. Just because wccftech say something does not make it true. Its possible that the AMD guy was hinting at the 295x2 design, however not sure i even believe that as it was a long way off.
“The next coolers are better. Although I can not go into detail for the next generation, however, we have some changes made to the cooling system. The cooler the Radeon HD 7900 series was in fact no great shakes.”
Above referring to the 295x2 cooling system, maybe. ^^
” not interested in their own reference design attractive – and thus connected: costly – to make “.
Above referring to the standard AMD reference design. Actual quotes from the AMD guy. (supposedly)
If this was from another site than wccftech, it may be more credible.
Also worth noting that the 8000 series they were referring to are simply rebrands, not the 290 series.The rebranded 8000 series (which became 280 and 280X) were all non reference design.
That does not sound like a we will make a brand new better reference cooler to me.
Not sure how you can deny what wccftech are saying when it clearly states an AMD Manager said. I don't think you work for AMD (yet), so I can't see how you can dismiss it so easily.
It's a science thing![]()
Don't confuse the heat coming from my case with the temps of my components. It is all about heat removal and my waterblocks/Rads/pumps/fans all do a fantastic job of removing that heat.
