- 12 Feb 2014
- Somewhere Only We Know
Best pump / res combo I ever brought below, very space saving, however you dont actually need a res if your struggling for space, you can just buy a T piece and connect a long piece of pipe to it, to use as a fill port, just need some sort of blocker on the other side.
Just did a very quick edit of your picture to show you what I mean, obviously the fill tube or return line doesnt have to be so long, its up to you where you route them to, you could always move the pump closer to the top then near the other water cooling components to make all the pipes shorter.
