What would be the best way to setup my lwatercooling loop in haf -x case
Best pump / res combo I ever brought below, very space saving, however you dont actually need a res if your struggling for space, you can just buy a T piece and connect a long piece of pipe to it, to use as a fill port, just need some sort of blocker on the other side.
Just did a very quick edit of your picture to show you what I mean, obviously the fill tube or return line doesnt have to be so long, its up to you where you route them to, you could always move the pump closer to the top then near the other water cooling components to make all the pipes shorter.
so if I was to have it like this with one or two of them fittings
which side one the bottom, single port end or multi port end ?
also how will the port at the front allow me to fill and bleed ?
The single port end and one on the base of the multi port end. This leaves the two on the front free for filling and bleeding.
Basically how you've got it in the picture, but with the 90's on it instead.
First pic in the above post: Is there not room to turn the pump 90°?
Second pic: I'm still advising you not to have the res intake at the top, but you might get away with it.
there is some room but it does not make much difference as you can see in the pic.
also if I was to go with image 2 and put the res intake at the bottom, how can i fill and bleeds ?
You'd use the port at the top as is normal :)
The ports at the bottom would be used for inlet/outlet.
In the first pic in post #32, how does it look if you swap the 45 and 90 fittings around?
finally got there in the end,
thanks for the help Uncle Petey and everyone, ill be set it up a bit later, ill keep you updated on how I get on.
Im having a small issue most of the setup went well exept 2 thinks I had one loose fitting which ive fix. The only iw im facing which I cant understand is a leek on the cpu block . It seems to be around the 45o fittings iused and it only happens when the pump is on. I cant tell if ive not tighted then well. Wich ive double check or the seel around the moving part of the fitting.
Xan anyone please help
What can I do
