- 25 Mar 2004
- Fareham
Pretty much any wep you use needs a socket, the extra 130% CHD you get from the top tier Emerald is too good to pass up as a DPS stat imo.
Fair enough - I didn't really address the offline mode because I didn't think it important.
No, that's not really fair - I didn't think it insurmountable. I don't deny that D2's offline mode may have been pants (I honestly don't remember!), but I don't see why Blizzard can't make a proper offline mode with some thought. There's no reason you can't allow resetting/repeating requests in an offline mode, and then its back to the old school method of downloading a patch and installing it when you can rather than streaming it through battlenets patcher.
We'll never see PvP in D3, that'll probably be some method of selling D4 so the game doesn't need protecting/balancing around that.
I'm working towards a perma-Archon build for my wizard, focusing on cooldown reduction and arcane damage %.
I played the build for the 1st time last night and it was awesome! My gear is still a work in progress but I have 57% cooldown reduction and around 65-70% +arcane damage. I still have 4 pieces of gear which I need to re-roll CDR on, which will give me an additional 25% or so.
Was able to complete T1 rifts in under 5 mins, feels so much better than my old frozen orb build even if I had 1.6m dps with that.
Link?
Marauder set + Garwulf's and Tasker and Theo is crazy.
what are people farming at lvl 70?
ive just been doing norm act 1 split runs for an hour, got about 20 cache and got sweet fa out of them or the blood runes.
You crit hit:dmg ratio is outside what I'd expect, it's usually 1:10 and you're 1:5 and with pinpoint it will likely be worse. I've read (totally no math proof here) that the goal target is 1:10 and running either side of this is OK but not "optimal". You can fix a lot of it with paragon usually. Running glass cannon won't really work too well with your goal of survival but that might be because you were doing norm runs or something. You have low +skill and +arcane which is fine but will stop you from killing stuff fast. You could run Dynamo instead of glass cannon thinking about it, might be better kill times. Your boots are running the wrong +skill.I have quite good buffed sheet DPS with my Wizard, but am struggling with survivability in T3+.
Any suggestions?
http://eu.battle.net/d3/en/profile/PMKeates-2158/hero/35624078
