Alloy Wheel Cleaner?
bJN
bJN
23 Nov 2009
Norwich
I use Meguiars Hot Rims to clean mine, brings them back to sparkling-new! Just use a little brush and plenty of water from the hose! :)
19 Jan 2003
Bristol, UK
Bilberry is nothing compare to Bilt Hamber. I tried loads of different cleaners and none of them would shift brake deposits from my refurbished alloys. Bilt Hamber wheel cleaner did the job though, kept them looking like fresh refurbs!
4 Nov 2004
Beds
If you're gonna use bilberry then get the original stuff from Angelwax rather than valet pro.
Or get them clean, apply a decent wheel sealant then just use shampoo from then on
