*** The Official Diablo III Thread ***
Status
Not open for further replies.
Staples Kashmir chair reclines and has soft arms, usually in a half price sale and is very comfortable. Some will tell you no computer chair is good though unless you spend over £200.
Only idiots who are suckered into buying those overpriced bucket seat "gaming chairs" make recommendations like that to others (£200+)
You can get quality for a bargain if you look for it.
They are usually the same people who think that you need to spend £1000 on a watch to tell the time though :P
So it would seem anything above T3 is too much for my Monk. It's the ground effects, they absolutely destroy me. Tank based on dodge chance is entirely broken as far as ground effects go, especially for a melee class
Think the main one is full but there still room in the Social clan,
In clans make sure you choose the English (British) filter on the left then search for Overclockers
You should see two results, apply to join the Overclockers Social clan and I or someone else will accept you asap, also drop your battlenet id here so I know who you are there's been a few random people applying to join, must be from playing with clan members on publics.
Just applied to join foey#2315 :)
Any crusaders here? Need some advice on wrath generation
here is my current set up
http://eu.battle.net/d3/en/profile/kmax86-1270/hero/39543678
My main wrath generation is provoke + shield glare. Problem is when both are in cooldown or there are not enough mobs ie boss fights I struggle to generate fury as my 2hander is very slow :\
Currently farming reapers wraps but Ive been so unlucky with stat rolls
Same on my WD as I have to stand still to do dps, otherwise its pure pet damage. The rare mobs that use those fire chains destroy me, as do poison based attacks it seems! Can survive standing in lava for a while though lol.
Whats your attack speed mate? Most of my attack is my main weapon. I have sweep attack which clears a vast amount at once.
Mine for comparison :- http://eu.battle.net/d3/en/profile/foey-2315/hero/39403618
During Boss fights I use shield glare and then Heaven's Fury & Condemn, when I run out it builds up pretty quick. My Crusader hits pretty hard. I'm seeing 1.1m DPS on the Character window.
I'm farming T2 & 3.
On your 2H, I would have rolled the Vitality for a socket. Its a must have for a 2H.
Base atk spd is 1.14
Combat is 1.42 (Fervor + Celerity)
the 2H I can only pick Str or a socket unfortunately. Still debating if should go socket as 1k str seems a lot.
My play style on boss fights is to use Akarat, Valor Force and surround them with Fissure lightning while I have aggro so my weap and belt will proc. All is good on the initial encounter as usually there are trash mobs so wrath generation is easy but when the white mobs are dead Im noticing some lag time before I can spam Fissure lightning again.
I came from barb so im a bit spoiled with Superstition where I just stand on **** and I get fury :D
My Stats in town.
I should really play around with other builds - just got so used to this. Really enjoy playing Crusader :)
My Stats in town.
http://i61.tinypic.com/143g5fp.jpg [/IM]
I should really play around with other builds - just got so used to this. Really enjoy playing Crusader :)[/QUOTE]
Cheers. Did some quick comparison and clearly my crusader lack strength.
Also seems that the atk speed from cains set really helps. Gonna have to start farming magdha and Malthael for mats now.
I didnt expect to switch to crusader as I just tried it as I got the 2h lightning weap + thundergod while playing barb and thought it would make a good combo. Ended up liking lightning effects its like shard of hate/thunderfury :cool:
So just been power levelling a WD, first time ever playing one what's the current cookie cutter build? :p
Luckily there isn't one, so you can pretty much get away with doing whatever you are actually doing. The early "builds" seem to focus on pets and acid cloud/firebats spam, whilst the geared "builds" focus more on either dots or boosting pets to truly daft damage levels via specific legendaries.
You have a lot of utility with a WD though so you can mix and match it up how you see fit without any real issues before T2, regardless of gear.
I've been really enjoying the witch doctor class, got myself not not too shabby gear now and the amount of effective different builds are staggering, im currently on a pet fetish build using firebats to pew pew while my 15 strong pet team tanks.. its fun!
Archon wizards here: What passives do you use? Do you go for as much crit/crit dmg/arc dmg as possible? also is attack speed very good for disintegrate?
Well I had an awesome night last night. The other day I got the plans for the Aughild's Authority set but had only one of the legendary crafting pieces for it. I crafted some shoulders and they were awful so just sharded them immediately.
Last night I decided I would farm up a few of the crafting materials needed and see if I could get a nice shoulder and bracer combo. I managed to get three of the “Shard of Entsteig Plate” needed in about an hour and then crafted another set of shoulders, which were again awful.
Then I crafted another pair of shoulders and got pretty lucky. So I decided to try the bracers as well and again got pretty lucky. Not perfect rolls by any measure, but a very good start.
Then to top it all off, while testing out the gear in a rift a legendary sword dropped. Could it be? I have been hoping for a thunderfury or shard of hate for quite some time now, but after the luck with the crafting I couldn’t possibly hope to get the sword I wanted as well. Could I?
Damn straight I could. I looked in my bag and saw the thunderfury outline under the question mark. Identified it and it rolled pretty well on top of everything else. Again not perfect but it had already rolled a socket and strength so it was a pretty good start.
Armory Link
Luck wise I assume I am now screwed for the foreseeable future.
Rift it Forward is amazing. Got 1000 bloodshards last night and it only cost me 15 rift keys.
Not to mention those 1000 shards were collected in about 1 hour. Would recommend.
Even if you enjoy rifting solo, you can get your rifts opened for free and never have to worry about getting keys all the time.
Status
