snips86x, why don't you put up a wanted thread in the MM if you're on a budget and see if anybody has a decent pump or cpu block going?
That will be my intention. I'm researching first however as I want to ensure I've got everything I need to get it right the first time round. I'd hate to buy an incompatible product or wrong item.
I'm still planning how I wish to plan my loop, order and components and when I want to add my GPU into the loop also. Once I've planned it 100%, I'll stick one up.
Shouldn't be too long!
Are there any metal combinations I need to be aware of?
Metal-wise, generally most metals are fine together, just avoid mixing aluminium with anything. Most of the blocks nowadays are copper / nickel and most rads are copper which are fine together.
