Changelog for Patch 1.3001
S.T.A.L.K.E.R.: LOST ALPHA Patch v1.3001 (2nd of May 2014.) changelog:
The patch is savegame compatible, so You do not have to start new game for this patch, but for maximum experience it's recommended.
If you installed 3rd party / user made fixes and mods for Lost Alpha, it's highly recommended to reinstall the game to have a clean install before you apply the official patch. This is required to avoid conflicts with the 3rd party content. We can not give support for such cases.
- game will work on windows xp op. system, although dx10 cannot be used on xp
- new fsgame.ltx to solve the saving / loading problems for users who installed the game to Program Files
- quicksave / quickload buttons now can be remapped
- fixed serious bug with wrong ui_movies.xml which prevented to play half of the game
- fixed storyline battery task in sarcofag
- fixed flying tree and geometry on Yantar level
- fixed geometry on Garbage level
- fixed the crash on r1 (static lightning) render when player entered 'Great Metal Factory' level
- fixed rat monster crash and effectors bug
- fixed random crash related to pda contacts section
- temporaly disabled legs/shadow in options, if you have it enabled, please type this to console: g_actor_body 0- with removing visible leg feature, the missing footsteps and self shadow works again by default
- "la options" debug menu is disabled on widescreen
- crows are killable
- ak74, ak74u, L85, G36 sounds synchronization fixed
- proper fix for safe crash
- missing "chmieltist" beer sound fixed
- missing p90 model added
- brightness, gamma and contrast sliders fixed
- no available phrase to say, dialog[yantar_sakharov_start_talk] fixed
- no available phrase to say, dialog[agr_ratcatcher_start] fixed
- several (hopefully all) missing descriptions added back
- crash when player ESC from solitare and hex viewer fixed
- restored working class for hex viewer, text viewer, image viewer, console
- same fix for artefact merger
- crash in repair window fixed
- wrong passwords for doors in pda fixed
- loading last save overlap window fixed
- added marker for 'strelok's flash' and 'yantar wires' because many users reported it's too hard to find them
- fixed camera position to climb out of UAZ jeep
- fixed OnMouseAction crash (Tetris in LA PC)
- Veles gives correct download module, so no need to buy it from Barman
- updated mi24 model, should fix "callback kils bone matrix bone: front_gun_tower"
- improved tasks and task completion on agroprom
- fixed luminocity and distance for stalkers to default value, ai works better
- removed the strange reverb when eax is enabled, and added more stable sound dlls
- temporary fix for missing suit upgrade
- fixed incorrect mag size for upgraded pb1
- added vehicle prices to dialogue
- corrected outfits icons and soldier outfit
- new helicopter sound with tuned volumes
- added pda articles for downloads
- missing vehicle icons were added
- several vehicle properties were changed- various small tweaks and fixes
