** Bank holiday Special Edifier Spinnaker 2.0 Speaker System - Black £89.99**
7 Feb 2011
Stoke on Toast
Hi guys got a bloody silly bank holiday special for you all this weekend Offer ends on Tuesday at 09:00 or when we sell out if that happens.
These fantastic speakers are a bit unique and not everyone's cup of tea but they are packed full of features and pack a decent punch on sound too.
Edifier Spinnaker 2.0 Speaker System - Black @ £89.99 inc VAT
The award-winning Spinnaker by Edifier is an iconic system, standing 15 inches tall the abstract shape is designed to be visually striking as well as a facilitator to enhance the audio performance. The shape projects sound towards the listener with a 19mm silk domed, front facing tweeter, a 23/4 inch mid-range driver, reinforced with a downward firing 4 inch subwoofer in each satellite. The Spinnaker is Bluetooth enabled, allowing audio connectivity to any Bluetooth device that supports both A2DP and AVRCA profiles for versatile track navigation, play/mute and volume adjustment through the multi-functional dome-shaped remote control. The remote control operates on a 433Mhz radio frequency up to a 10M radius making all control options easily accessible without the disturbance of inanimate objects. An optical and auxiliary input port is also available for connectivity to other external multimedia devices simultaneously. A speaker-output port allows an external subwoofer/speaker to be connected for additional base performance, making the Spinnaker a versatile system for both home and office use.
Frequency response: 68Hz - 20kHz +/-3dB on reference axis
Frequency range: 50Hz - 23kHz -10dB
Crossover frequencies: 135Hz -10dB
Distortion: 0 0.5%
Input sensitivity: 800mV±50mV
Audio input: Bluetooth, Optical, Auxiliary
Audio output: Bass expansion for outboard subwoofer
Adjustment: Wireless remote control
Power supply: Input 100V-240V AC, Output 20V/60W DC
Speaker unit: Treble: 19mm silk dome, Magnetically shielded, 4ohm Midrange: 2¾ inch (70mm), Magnetically shielded, 4ohm Bass: 4 inch (116mm), Magnetically shielded, 6ohm
Dimension: 140mm x 413mm x 189mm (W x H x D)
Weight: 4.3Kg (net) | 5.3Kg (gross)
Total power output: RMS 10W x 2 +10W x 2 + 25W x 2
Was 279.95 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Yup if you're going to do a bloody silly price you may aswell do it properly I'm even cheaper than a certain rain forest ! :D
Any idea on how these would compare to the Creative T40 MKIIs?
I can't say from personal experience but I can tell you that Edifiers higher end speakers have always been of superb quality you're geting 45W per speaker that's nearly three times as much as the R1600T's with bluetooth and optical inputs too.
I think these speakers are a bit of a mental design and the price was too much to match we've never had a return of these speakers though.
just checked the creatives are RMS 16w per channel like the R1600T's
also, I have heard a pair of these when we first got them in.
they are every last bit a £200 speaker set. full sound, very nice dynamic range with detailed highs and acceptable bass.
they are not the best speakers i have heard in my whole life, but for less than a hundred boys, you arent going to find anything better.
And if you are bored you can stick them to a metal bowl, put it all on your head and re-enact the classic Amgia game "The Lost Vikings" :)
Seriously, I remember listening to these when they first arrived at OcUK, and they are bloody good speakers. I'm a bit of an audio-phile too, so to get me to say that they are bloody good takes some doing!
Damn. Caved in and ordered for the missus to use in the kitchen, as she should be able to stream music to them from her iPhone. Hopefully she wont then notice the other stuff that found their way onto the order.
If she doesn't like them, can you recommend a good metal bowl Ace?
:D
