- 20 May 2009
You will generally find that the more watts you put through this TIM the better it operates.
Generally speaking in data (so far at stock) you get between 3 and 5 degrees better temps than AS5. However start overclocking or using a high watt cpu etc and that difference widens a great amount. Anyway try for yourselves
Remember to warm the ICD up before applying and DO NOT attempt to spread the paste youselves, let the block or HSF do that.
I am going to test it on my i7 920 @ 4ghz. Will be interesting to see what temps I can get as the cpu can run hot.
