This is the second 2400mhz kit ive had, the first was a patriot venom red c11 kit, though it turned out to be faulty. Got the team stuff as a replacement, same price as the patriot but better primary timings. Seems that ocuk only stock the c11 kits now.
Thanks guys , much appreciated and insightful stuff. @setter - your xmp seems much lower clocks from what the beast provides. For instance your TRFC shows 193 clocks ,, on these its 312 at XMP
@PGI - nice pointers. though at the moment i have zero movement on those main timings. It just does not boot. Im thinking possibly its lack of voltage bumps in the correct places as you mention. could you explain these "(remember to nudge up SA/IOA/IOD/PCH/DRV too!) " in full form and ill apply go again tomorrow.
Thanks to all. ;D
SA = System Agent, sometimes known as VCCSA
Running 1.2 on SA, IOD/A and PCH here. Anything lower results in 1A memory management bsod's.
Ill see about lowering PCh a tad, however though ive recently had to up cpu voltage due to whea errors and related 0x124 bsod's in games. But even before that this has been an extremely hot chip. 1.265v under p95 fft resulted in 94c on one core inside 3 seconds.That can't be helping your temps bud, PCH is killer for high CPU temps.
Nope, 1.85. Basically it's the voltage applied at post, VRIN on a gigabyte. It's explained better here.You mean 1.185?
Try dropping the cpu multiplier and raise cache multiplier, perfecting efficiency on haswell can be far more beneficial then going for raw mhz![]()
